O2 Sensor Recommendations
Old Jul 31, 2018
Pochop1964's Avatar
Pochop1964 is an unknown quantity at this point
I need a recommended o2 sensor up and down stream for 03 ex. Good less expensive ones?
Old Jul 31, 2018
Colin42's Avatar
Re: No start, knock/tick
Use the proper Denso ones. You can get the part numbers from their website. Then buy them on Amazon from a reputable seller for a decent price
Old Jul 31, 2018
Pochop1964's Avatar
Thanks that is what I am seeing from others!
Old Aug 1, 2018
Re: O2 Sensor Recommendations
If you still have the original factory sensors, check what brand each one was. You might need to wire wheel the rust off of the sensor to read the brand names.
Original sensors were Denso or NTK. Could be both.
Replace with same brand the factory originally used.
Old Aug 1, 2018
Pochop1964's Avatar
Will do. Plan on doing it this weekend.thanks for ur help.
scottyd540
Apr 6, 2014 11:36 AM
jrnevada
26
Mar 3, 2014 11:21 PM
Dreyko
Jan 4, 2013 01:10 PM
Damname
Mar 14, 2011 08:45 AM
HELP_ME
Sep 22, 2004 07:16 PM
