Battery drained and car won't start after charge
Old Jul 16, 2018
yiplong's Avatar
yiplong is an unknown quantity at this point
I noticed intermittent battery light today, it seems to come up a lot while the vehicle is stopped or going at low speed. The car also jerks sometimes (not sure if this is related to the electrical problem). Things quickly got worse before I can take it to the shop. First all the instrument panel gauges went out, then the lights, then turn signals. The car barely made it to my driveway before dying.
I charged the battery for a total of 40-50 minutes. Now the lights, instrument panel gauge, stereo, etc. all work, but when I turn the key the engine doesn't crank and there is no click at all. Usually when the battery is too weak to start the car, the engine will still attempt to turn over. Maybe I blew a fuse or something while charging? Or is this some security feature that's preventing the car from starting?
Any ideas what to do? I just want to get it started so I can drive it to the shop two blocks down the road. I have another car, maybe I will remove that battery and install it in the Civic and see if it starts.
Old Jul 16, 2018
GolNat's Avatar
Prelude Owner
Re: Battery drained and car won't start after charge
If the battery is not holding a charge then it won't be able to start the car. It may have a shorted cell internally and it didn't accept any of the charging that you gave it. Your alternator could also be bad and not charging the battery which is usually when that light comes on.
How old is the battery?
Do you have volt meter?
Old Jul 17, 2018
Slumpertcivic's Avatar
Stock, the alarm won’t interfer with the starter.
It is possible you blew a fuse, but first thing I would do would be to take battery out and have it tested at parts store.
Old Jul 17, 2018
yiplong's Avatar
Looks like it is holding the charge. The battery was completely dead when the car stalled, after charging for a while I was able to operate the light, the stereo, window, etc. The battery may still be too weak to get the engine started, in this case it will usually attempt to start and make a "click click" noise. I didn't hear anything when I turn the key. This is odd.
I don't have a volt meter. I will consider buying one or getting the battery tested at a parts store. Or install the battery from my Toyota in the Civic and see what happens. Thanks for your help.
Old Jul 18, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Make sure the alternator bolts on bracket are not loose as this is the ground for the alternator and have created many problems including yours. The adjuster bolt can become stripped too. Check your alternator also.
Old Jul 20, 2018
yiplong's Avatar
Re: Drained battery
So I bought a new battery, same thing. When I turn the key, the lights come on, radio etc all work, but the car won't start. There is no crank. What should I check next? A blown fuse or maybe overzealous anti theft (I have stock security).
Old Jul 20, 2018
Re: Drained battery
Moved post to correct thread.
Bad starter? Clutch switch? PRNDL switch? Test!
Old Jul 20, 2018
Alfie17's Avatar
Alfie17 is an unknown quantity at this point
Start with the easiest thing first, test for a bad starter. Have someone crank the car while you tap the starter with a wrench or something and see if it starts. Starter is under air box on the transmission side of the engine.
Tooms8
Aug 5, 2018 05:03 PM
smithhonda03
May 16, 2012 12:10 AM
AllMotorSi
Apr 16, 2005 01:16 AM
streetglower
Nov 10, 2004 12:47 PM
ophion
Apr 5, 2004 05:19 PM
