02 civic 1.7 auto lx sedan vibration at 70 plus
Old May 29, 2018
jdub122's Avatar
jdub122 is an unknown quantity at this point
hi everyone,
3 years ago the tranny went out and followed wrenchers post on cleaning the screen in the tranny. i replaced the screen, clutch discs and plates, added a B&M transmission cooler with B&M filter. About 3 months ago i changed the trans fluid and replaced the B&M filter with a fram filter.
i'm taking it tomorrow to make sure its not a tire, wheel, or alignment issue.
could the fram filter not allow enough line pressure?
could it be a solenoid?
it drives pretty straight accelerating and stopping
and the tires have about 30,000 on them with good tread.
I'm going to drive it tonight and see if it does it in 3rd gear.
any suggestion are welcome.
Old May 29, 2018
Slumpertcivic's Avatar
Re: 02 civic 1.7 auto lx sedan vibration at 70 plus
Very normal for unbalanced wheels to not be noticeable until high speed.
Rotate tires on one side and take for a test ride, repeat on other side if you don’t notice a change. At 30k it’s due for a rotate anyways.
if your still getting no change after moving all the tires, might be a axle/bearing issue.
Old May 29, 2018
Tire inspect and balance first
Old May 29, 2018
jdub122's Avatar
thanks i have replaced the front bearings
it might be ready for rear hub assembly also
thanks again
Old May 30, 2018
jdub122's Avatar
balanced and rotated tires and had it aligned drives great now thanks
CDelaney94
Feb 24, 2015 05:29 PM
itsfighter
Nov 25, 2012 09:01 AM
MangoEX
15
Aug 20, 2003 10:05 PM
