So the dealership said I need about 2200 bucks worth of stuff done.
Old May 15, 2018
thesupersoap33's Avatar
thesupersoap33 is an unknown quantity at this point
I honestly believe they felt sorry for me. Or I felt sorry for me.
Needs control arms sway end links new struts all around a positive battery cable and said there was oil "seeping" out of the motor. 362k... she's old.
so idk what to do. Do I fix it? I can't afford a new car and honestly can replace everything myself, not including the oil drip problem.
anyone even know where I can get motor mounts for a 2004 Honda civic hybrid?
they said 2200 in parts alone and I priced the aftermarket route and I'm looking at less than 400 bucks if I can find an aftermarket set of motor mounts for a hybrid. Apparently, the hybrid and 1.7L don't have the same mounts
Old May 15, 2018
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: So the dealership said I need about 2200 bucks worth of stuff done.
Did you check rockauto? I see they have them for the hybrid
Old May 15, 2018
Hell yeah! Thanks!
Old May 15, 2018
Or if you want honda OEM stuffb hondaautomotiveparts.com is a good bet. I think coupon code ship50 works for half off shipping costs
Old May 15, 2018
Colin42's Avatar
Struts are easy to fit if you but the complete assembly (quick struts).
sway bar links aren't bad, same with the control arms, check the balljoints while you're there.
How bad is the oil leak?
unless you're losing alot of oil I would ignore it.
Does the battery cable just need a new terminal?
Getting good quality aftermarket parts are usually cheaper than Honda parts, double check pricing between the two of them though sometimes the Honda part is cheaper
Old May 15, 2018
I asked the guy at the counter about the leak and he didn't specify. He said it wasn't bad but it was coming out. Probably a gasket here or there.
The ball joints will probably need replacing too. I just need to come off of the dough and say that it's worth it in the long run.
Old May 15, 2018
Second opinion can be valuable
sL3epy
South Cali
16
Nov 10, 2005 01:36 AM
bgoetz
21
Feb 23, 2005 02:29 AM
HondaHottie
Dec 7, 2004 09:25 PM
BoostedCivicZex
Feb 16, 2004 06:03 PM
LuZi0n
Sep 9, 2003 10:38 PM
