Ep2 1.6 vtec sport
Old Apr 30, 2018
Apooh's Avatar
Apooh is an unknown quantity at this point
Ep2 1.6 vtec sport
Hi all im new to driving honda civic 1.6 come across a little prob p0171 now ive put a new performance air filter kit on her and changer 02 sencor cleared it using obd2 and app but every time I put my foot down it pops back up any ideas what it could be
Old May 1, 2018
GolNat's Avatar
Prelude Owner
Re: Ep2 1.6 vtec sport
Go back to stock and see if the code pops up?
Could be vacuum or exhaust leak.
Old May 2, 2018
Apooh's Avatar
Didnt come with stock air filter just replaced with same parts but this kit was for this car and also replaced o2 sencor was thinking of cleaning maf? Also was going to give it a service has well but I had a problen fitting air sencor to it its loose fit but cant find what its called so I can bye one
Old May 2, 2018
GolNat's Avatar
Prelude Owner
Doesn't have a MAF.
What o2 sensor did you put in it?
That's probably the MAP sensor. Does it go in the intake pipe before the throttle body? That being loose could maybe cause that?
Old May 2, 2018
Apooh's Avatar
Yes it does and its loose and got a fitting for it today well a rubber ring to replace old one will try replace that tommo also got electric spray for sparks plugs and connections to just to rule everything out
Old May 3, 2018
Apooh's Avatar
P0131 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 1, bank 1 -low voltage having no look today replaced oxygen sensor cleaned map sensor what else could it be
Old May 3, 2018
Colin42's Avatar
did you put the correct sensor in?
Old May 3, 2018
Apooh's Avatar
P0131 and p0132 Omg bad look I put old 02 sensor back on cleared coads to now have them to started off with 1 now 2 lol what do I do
Old May 3, 2018
Apooh's Avatar
Its also runs lumpy and wont go past 3000 revs but when engine light comes on its runs normal drives all the was to 7000 revs
Darren16
Oct 5, 2012 03:44 PM
themystic
Dec 30, 2009 05:16 PM
Itam
Buy, Sell, & Trade - Archive
17
Apr 15, 2005 09:11 PM
nightkids1
South Cali
16
Apr 26, 2004 12:27 AM
briggzy
Mar 20, 2004 11:36 PM
