Problem with power
Old Apr 28, 2018
Emilio216's Avatar
Emilio216 is an unknown quantity at this point
Problem with power
I have a 2001 Honda Civic I jump start it and it starts after a while it shuts off I have changed the coils knock sensor alternator battery spark plugs and edl and I still keep losing power what can it be
Old Apr 29, 2018
Wankenstein's Avatar
Re: Problem with power
Originally Posted by Emilio216
I have a 2001 Honda Civic. I jump start it and it starts but after a while it shuts off. I have changed the coils, knock sensor, alternator, battery, spark plugs and edl. However, I still keep losing power... what can it be?
Inspect and clean all engine and chassis grounds. make sure all connections are tight.
Any CEL's?
A combustion engine needs fuel, spark and air so which one is deficient? Fuel getting to fuel rail and injectors?
Is timing correct?..maybe jumped tooth/teeth.
Old Apr 29, 2018
Emilio216's Avatar
I have checked everything everything was good timing belt gun storm good for you I even change the O2 sensor and still lose power after a minute
Old Apr 29, 2018
Emilio216's Avatar
Could it be any of my relay
Old Apr 29, 2018
Stop throwing parts at it..test first. You've probably spent hundreds of dollars already and the issue still remains.
Are you saying you checked ignition timing (distributor) with a timing gun? If so, that is not mechanical timing (crank/cam alignment).
Old Apr 29, 2018
I jump start it
Because the battery is dead?
Because the alternator is not working?
Seabass
Apr 24, 2006 10:36 AM
