Coolant leaking
Old Apr 24, 2018
StockTech's Avatar
StockTech is an unknown quantity at this point
Red face Coolant leaking
Hi, this is my first time on a forum so im not too sure how these work but figured id give it a shot. i have a coolant leak near the driver side, rear side of the engine. i stuck a camera in there to try to see where exactly it was coming from and it appeared to be coming out of a hole that sort of looked like a plug belonged in, and it was coming out in large amounts. does anyone have a clue what this might be? I have done some research and was under the impression that this might be something called a weep hole?
2001 Honda Civic EX Coupe
Old Apr 24, 2018
GolNat's Avatar
Prelude Owner
Re: Coolant leaking
Did something happen like overheating?
Might be a freeze plug? Can you find a diagram of the engine online and circle about where you are talking about?
Old Apr 25, 2018
Wankenstein's Avatar
Re: Coolant leaking
I don't think these (7th gen) engines have freeze plugs..6th gens don't, anyway.
The water-pump most likely has a weep hole (by design). If it's leaking from there it's time to replace the water-pump. Put a large (spot-free) piece of cardboard (size of engine) under your car and let it run from cold start to operating temp for 20 minutes or more. Check the cardboard to isolate area of leak. If you don't see any leaks put the cardboard back in place during cool down and check again when engine is cold.
Another possibility is the block's drain plug: drains the water-jacket that surrounds the outer pistons walls. It's located near the the driver's side under the intake manifold. It's a large bolt (IIRC 21mm) and has a one time use crush-washer. The washer is most likely the cause if it's leaking from this location . Did anyone do a drain and fill recently and remove that bolt/washer? Cardboard will help identify that location also.
Old Apr 25, 2018
StockTech's Avatar
Re: Coolant leaking
Overheating does occur and i believe the leaking starts idI say about when it starts to warm up, I have the video but I'm not sure how to upload it to show you guys. I just bought this car so I'm not sure what work has been done to it up till this point.
Old Apr 25, 2018
Skitree's Avatar
Skitree is an unknown quantity at this point
Re: Coolant leaking
Almost certain it will be the weep hole off of the water pump.
Old Apr 25, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Coolant leaking
I hope the previous owner didn't just offload this vehicle to you with a bad head gasket - which is common in these engines. Lots of info for you on failed head gaskets on this site.
Old Apr 25, 2018
Re: Coolant leaking
Post video to you tube and then linkyour YouTube vid here.
Old Apr 25, 2018
StockTech's Avatar
Re: Coolant leaking
Sorry for the long video, skip to around 0:45 to see it.
Old Apr 25, 2018
Colin42's Avatar
Re: Coolant leaking
Wow, that's leaking good.
Yeah thats the weep hole, do the timing belt and tensioner as well while you're in there (use honda parts)
Old Apr 25, 2018
Re: Coolant leaking
Fire your camera-man..lol.
A bit tough to get a reference point form all the camera motion and it's hard to tell if you're above or under the engine from the halfway point onwards in that video. Looks to be the water-pump weephole but a view from underneath would be helpful. Similar to this:
Old Apr 25, 2018
StockTech's Avatar
Re: Coolant leaking
lol yeah wasn't the best video but thank you for the suggestions, i think im going to replace the water pump anyways considering the sticker in the engine bay says it should be replaced in about 8,000 miles. ill be sure to update the thread with a better view also. thanks!
Old Apr 25, 2018
Slumpertcivic's Avatar
Re: Coolant leaking
OEM waterpump will last much longer than generic, a asani is comparable for bit cheaper.
Old Apr 25, 2018
StockTech's Avatar
Unhappy Broken Water pump bolt
okay so i ran into another issue, while replacing the water pump a bolt holding in the water pump has snapped off, i do plan on extracting it but does anyone know where i can purchase new bolts at? i called Oreilly's and Autozone but neither of them had the bolts? where would i be able to buy new ones? or will i have to try to proceed with 3 bolts instead of 4?
Old Apr 26, 2018
BrotatoChip's Avatar
Super Moderator
Re: Coolant leaking
Looks like there are two different lengths being called out, both are M6 flange bolts (22mm and 30mm in length). Both of the Honda part numbers are below, you will have to decide which you need. You could also go to any hardware store and find an M6x1.0 flange bolt that is 22mm or 30mm long depending on what you need.
M6x22
95701-06022-08
M6x30
95801-06030-08
Old Apr 26, 2018
mikey1's Avatar
Re: Coolant leaking
Sorry for the long video, skip to around 0:45 to see it.https://youtu.be/S27RjNaBrm4
probably unrelated to your problem.....but your coolant should NOT BE GREEN!
Old Apr 26, 2018
StockTech's Avatar
Re: Coolant leaking
M6x22
95701-06022-08
M6x30
95801-06030-08
Thank you for the information man, really appreciate it. looking over the bolts one of them were shorter so i believe it snapped cause while i was trying to torque it in, it might have been in the wrong hole
Old Apr 26, 2018
StockTech's Avatar
Re: Coolant leaking
Really? why so? does it use a certain type of coolant?
Old Apr 26, 2018
Colin42's Avatar
Re: Coolant leaking
Should be using Honda coolant which is blue.
You can buy it in pre-mixed jugs at the dealer.
I use normal coolant in my cars but don't tell anyone
Old Apr 26, 2018
mikey1's Avatar
Re: Coolant leaking
yes...honda OEM coolant is blue
Old Apr 26, 2018
Re: Coolant leaking
My 2003 civic was oem green coolant..
Old Apr 26, 2018
Colin42's Avatar
Re: Coolant leaking
I think sometime after 2005 is when they switched to blue
Old Apr 27, 2018
Re: Coolant leaking
OP: when you install the water pump follow the service manual's torque specs and crossing pattern. Also, would be a good time to install a timing belt kit if it's near the scheduled (service manual) mileage/years.
eswar_ner
Oct 8, 2014 06:12 PM
Lordsin
Apr 22, 2014 07:36 PM
satown210
Mar 2, 2011 05:46 AM
Thrasher086
May 11, 2006 11:35 AM
ricergribbs
Feb 2, 2005 04:35 PM
