AC compressor clutch/pulley issue
Old Feb 23, 2018
hapka16's Avatar
hapka16 is an unknown quantity at this point
So i had a bad bearing in my ac compressor clutch pulley which i was able to remove but due to funds I had to fix it right away so i bypassed the ac for 2 months. I finally got around to ordering a new pulley and clutch plate off ebay and am trying to get the pulley back on but i'm unable to get it all the way on. Any ideas of what I can do to get the pulley all the way on so that I can install the snap ring, clutch plate and nut?
Old Feb 23, 2018
Slumpertcivic's Avatar
Re: AC compressor clutch/pulley issue
You could try heating the pulley up to say 250 degrees in the oven, it will take good 30-45 minutes to heat up.
Then using oven mitts, take from the oven and hopefully it will glide right down the shaft.
Old Feb 23, 2018
hapka16's Avatar
Well the damn thing is halfway and i can't pull it off lol. I was thinking of taking a heat gun to it with some liquid wrench and then tapping on it with a rubber mallet.
Old Feb 23, 2018
Colin42's Avatar
You can try that, wouldn't hurt anything
Old Feb 23, 2018
Rubber mallet and a block of wood usually works for me when I do them in the car, alternate side to side so the pulley doesn't go crooked and jam up
Snout may have had a little corrosion from being exposed to the elements, should have cleaned that up with some emery cloth or similar .......
maybe some penetrating oil could help now.....
Tap the pulley back off, and start over?
Old Feb 23, 2018
hapka16's Avatar
Yeah I would like to do that. I'm gonna take off the washer fluid reservoir to give me more room to work. My plan is to get this done either tonight or tomorrow...unfortunately I work until 6:30pm and have two young kids at home.
Grimlock
40
Jun 19, 2015 08:25 PM
elamaranm
Feb 12, 2015 11:05 AM
scooty
May 14, 2012 11:22 PM
Civicnoobie
Jul 19, 2011 12:29 PM
gudoffer
Aug 12, 2009 09:35 AM
