Transmission Range Sensor/ Neutral Safety Switch issues, among other things...
Old Dec 4, 2017
Adam Underwood's Avatar
Adam Underwood is an unknown quantity at this point
Bought an 01 lx and had the transmission rebuilt. The transmission range sensor never worked, after changing it 5 times it still doesnt work right. This last one actually worked right for a few hours until going into a glitch like mode. It will show the prndl light up if you mess around (move the shifter up and down through the gears).
I'm not sure what to do about this so here's another problem, cruise control not working. Changed servo, the brains (module), several switches. I'm wondering if these two could be related. Thanks for any help.
Old Dec 5, 2017
Slumpertcivic's Avatar
Re: Transmission Range Sensor/ Neutral Safety Switch issues, among other things...
Did you check the ASCD bumper on the brake pedal?
Our cars are at the age when those break and fall off, when that happens the cruise control system thinks your foot is always on the brakes..
Old Dec 5, 2017
What are the fault codes?
cruise control not working. ....
Cruise can't work if it doesn't know the trans is in the right gear....
Old Dec 6, 2017
I don't remember the codes exactly but one of its descriptions was faulty T.R.S.
Old Dec 6, 2017
Cruise can't work if it doesn't know the trans is in the right gear....[/QUOTE]
Right, thats what I figured. The few hours that it was working the last time cruise control didnt work.
