ca legal exhaust 2002 civic ex?
Old Oct 8, 2017
310civicEX's Avatar
310civicEX is an unknown quantity at this point
ok so im in new mexico..about to head back to california.. got this civic ex with no catalytic converter and a header with 2 o2 ports... also an AEM intake.... none of wich will pass in california.. any ideas on what parts will work?
Old Oct 8, 2017
Re: ca legal exhaust 2002 civic ex?
The intake should. Should be a sticker with a CARB EO number on it. If so, you're good to go. I'm almost positive that all AEM intakes have CARB EO numbers.
If you want a header, the DC sports one is 50 state legal. Part number HHC5019
Downpipe with cat, the only thing that'll pass with CA is OEM. Be prepared to shell out hella money or find a pick-a-part with the downpipe still there.
Cat-back exhaust, as long as it's less than 95dB you should be good.
Old Oct 8, 2017
310civicEX's Avatar
it has a header.. i gotta go take a pic.. im almost positive wont pass in california
Old Oct 8, 2017
310civicEX's Avatar
i keep finding this image for 2002 civic EX... no 02 sensor?
Old Oct 8, 2017
not on the header. The cat on the ex is located below the car on the downpipe
an illustration of the differences between the dx/lx and ex exhaust systems I drew up a while ago
Old Oct 8, 2017
310civicEX's Avatar
that drawing is great... thanx.. i wonder if the vtec even has an AIR/FUEL ratio sensor...... your drawing also shows one sensor on the catalytic converter.. is that accurate? btw... heres the header on it...
Old Oct 9, 2017
310civicEX's Avatar
so according to your picture... is this the set i need for 2002 civic vtec?
Amazon Amazon
Old Oct 9, 2017
Get NTK or DENSO brand "oe fit" (or whatever they call it) sensors.
Each mfr has a website where you can look up their part numbers then do your searching.
Old Oct 9, 2017
310civicEX's Avatar
i need to get catalytic converter and oem header... basically i wanna put it all back stock.. to pass the california smog and safety inspection. but it has header and straight pipe.
Old Oct 9, 2017
310civicEX's Avatar
i just confirmed D17A2 engine. and found the 02 plug tucked under the subframe near lower firewall.. and other plug near thermostat.. with brackets to run the 02 wire.. straight pipe after header with no holes for 02 sensors..
Old Oct 9, 2017
Damn kids and their "upgrades" that kill performance and pretty much ruin the entire car.
