2002 5 speed ex civic
Old Sep 5, 2017
Conner.bjork's Avatar
Conner.bjork is an unknown quantity at this point
Question 2002 5 speed ex civic
My fifth gear started popping out every once in a while so I decided to replace the transmission and clutch, once I replaced it it drove fine for about a week and fifth gear started popping out again. What would that be? I think it's something with the linkage. Please help me!
Old Sep 5, 2017
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: 2002 5 speed ex civic
Mine doesn't pop out but just a slight tug on the shifter and it will pull out of gear. There's little rubber shifter bushings that go around the shifter to keep it tight. Maybe those are completely worn out.
Old Sep 5, 2017
Did you refill the trans fluid? Got leaking axle seals?
