Shift Cable 2005 Hybrid AT
Old Aug 10, 2017
Iccanui's Avatar
Iccanui is an unknown quantity at this point
Hi ! I have a 2005 hybrid civic that was having issues with movement of the AAT shift stick. Eventually the linkage that connects the end of the cable to the transmission itself broke and i am in the process of replacing it. I have removed it and am looking for a replacement part. I am hoping someone can direction me to a trusted and hopefully cheap as possible place to get the cable.
Thanks so much for your time for reading this !
Old Aug 10, 2017
robfarr56's Avatar
robfarr56 is just really nicerobfarr56 is just really nicerobfarr56 is just really nicerobfarr56 is just really nice
Re: Shift Cable 2005 Hybrid AT
I don't think cheap is going to be a part of this repair, unless you scavange one from a junk yard.
I found the section on the microfiche, but I didn't know which engine/transmission you have - there were two possibilities for an automatic.
https://www.hondapartsnow.com/parts-...ect-lever.html
edit: part number so you can search 54315-S5B-952
Old Aug 10, 2017
Iccanui's Avatar
Awesome, thanks for replying. I think im just going to order that. Few bucks cheaper then what i found too.
Old Aug 10, 2017
robfarr56's Avatar
I found some cheaper on ebay when I did a search on the part #.
But I didn't look closely to see if they were a match.
Old Aug 10, 2017
Iccanui's Avatar
Thanks for trying, i dont wanna mess with ebay on this anyway, its clear what i want from that site you linked. Ordered it, be here in a week or do and im mobile again, yea
Old Aug 10, 2017
robfarr56's Avatar
Good for you. Trusted sources is everything.
Old Aug 10, 2017
You may want to consult the actual TSB on this specific problem before ordering your parts, this TSB calls for more than just a cable by itself, this includes the trans lever your old cable end is seized to along with a couple other small items:
LINK
http://ww2.justanswer.com/uploads/hy...ic_shifter.pdf
Old Aug 11, 2017
robfarr56's Avatar
ezone, I'm sure it has been said before, but you are a tireless resource of information for the common person!
THANK YOU!!!
Old Aug 11, 2017
Iccanui's Avatar
LINK
Thank you so much, i was thinking it might be more then just the cable and i am in NY for a few years now, so road salt definitely could be a issue with what i now know is called the trans lever. The cable was broke anyway, so it had to be replaced, if not, i now know what else to do, thank you both so much ! Cheers to the bodhisattva's of car repair
bo·dhi·satt·va
ˌbōdiˈsätvə,-ˈsət-/Submit
noun
(in Mahayana Buddhism) a person who is able to reach nirvana but delays doing so out of compassion in order to save suffering beings.
