AC stopped cooling and then again started cooling
Old Jul 16, 2017
sdraza1's Avatar
sdraza1 is an unknown quantity at this point
We went to about 70 km away by highway, while on our way ac stopped working at perhaps 25 km and didn't come back as we drove to our destination. When coming back we turned ac on to see if it might work and started cooling and keep on running ok throughout the time while coming back home. what can by the problem. thanks
Old Jul 16, 2017
Re: AC stopped cooling and then again started cooling
Relay problem, clutch coil problem, clutch air gap, thermal protector, and more are possible.
Old Jul 17, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
In my case, the air gap between the A/C clutch and coil became too large over time that a shim had to be removed from the shaft to close that excess gap. Now the clutch does not disengage inadvertently and the A/C does not fade out while driving.
Old Jul 17, 2017
mikey1's Avatar
you obviously have a ghost in the system
Old Jul 17, 2017
Old Jul 19, 2017
speedy25's Avatar
speedy25 is an unknown quantity at this point
I did have a "ghost." AC worked, then wouldnt work, then wouldnt shut off, etc!
The real culprit was the control unit failed. Got a used one and no more problems.
-SP
Old Jul 7, 2018
sdraza1's Avatar
With any of the problems you mentioned, total compressor needs to be changed? This is what mechanic told me. thanks
Old Jul 7, 2018
Slumpertcivic's Avatar
If your system works for more than a few minutes at a time, it’s very unlikely a compressor issue.
Take it to a better shop...
Old Jul 7, 2018
HONDA sells all external compressor parts separately from the compressor.
My (personal) first choice is always to keep an original compressor as long as possible. As long as it has no internal problems. I very rarely need to replace compressors. I do replace clutch and coil sets very regularly.
Aftermarket normally only sells a complete compressor, you cannot buy just a clutch or coil by itself. Plus, when you buy aftermarket compressor they want you to replace additional parts or they won't honor the warranty on the compressor.
And...the aftermarket compressors I've encountered couldn't be fixed with Honda parts (clutch/coil). They weren't identical.
Aftermarket quality is a crapshoot. Many don't last...and sometimes they fail so bad it contaminates the entire AC system internally. That's not a cheap repair.
Search more in the forum. If your problem is excessive clutch gap, you may be able to remove a shim to get it working again. That's a FREE diy.
Old Jul 10, 2018
NDNV's Avatar
"Search more in the forum. If your problem is excessive clutch gap, you may be able to remove a shim to get it working again. That's a FREE diy."
For me, it was $30 labour and then I had my A/C back.
jkirk454
Air Conditioning
Feb 17, 2019 08:33 AM
stevenpsu
Air Conditioning
Jun 20, 2018 07:46 AM
kkiley
Mar 30, 2017 06:43 PM
JcivicW
Jun 2, 2010 02:22 PM
