04 Acura 1/7 el (civic in Drag :-) Ex noises
Old Jun 21, 2017
danilo1's Avatar
danilo1 is an unknown quantity at this point
Wife's EL 1.7 50k Miles has developed a bit of ex noise on first startup of the day Sounds like a leaky pipe. Disapears by the time the hi Idle turns off. Clearly heat expansion is retightening 'whatever' it is
Soo. Gasket/ring failure or possibly a looseness in the Cat to downpipe joint? Wanting to get an opinion before I start dismantling, blindly looking for the problem.
Old Jun 21, 2017
Re: 04 Acura 1/7 el (civic in Drag :-) Ex noises
Exhaust manifold cracked, or it's leaking between the manifold and head (loose hardware or broken stud)?
You could use a length of hose held to your ear as a stethoscope to pinpoint or at least narrow down the source of the noise before taking it all apart
Old Jun 22, 2017
danilo1's Avatar
Ooooh sounds ominous.
Thank you for the stethoscope idea.. will try it.
