01 Civic EX 4th Gear Problem, Automatic
Old Jun 11, 2017
Trinh Nguyen's Avatar
Trinh Nguyen is an unknown quantity at this point
Hi all,
I searched around and couldn't find solutions to a problem I have with my automatic 01 civic.
The problem I have is when the car shifts into 4th gear for the first time, and ONLY for the first time, it shifts a bit weird. The RPM will spike about 800-1k rpm up and then come down entering into 4th gear. Is this because I am not giving it enough gas and it has to rev up like that? I have tried adding more throttle but have had to same problem. When the car shifts into 4th again after this first shift, even at low throttle, the shift is smooth and you do not feel it.
Currently, my way of getting around this issue is to keep the car in D3 until about 40 mph and then shift it into D for a smooth shift into 4th.
Can anyone offer any help with this?
My car currently has around 110k miles. I have changed the ATF at 70k miles and again at 100k miles. My current ATF level is near the top of the line when engine is warm.
Old Jun 12, 2017
Wankenstein's Avatar
Re: 01 Civic EX 4th Gear Problem, Automatic
Sounds like early stage of shift flaring: https://www.youtube.com/results?sear...e+transmission
Thread: http://www.peachparts.com/shopforum/...do-i-have.html
Old Jun 12, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Strongly suggest you use only OEM Honda DW-1. A drain and fill every 3rd or 4th oil change is what I would recommend. But if you have another ATF in there, best get it out with a 3X drain and fill of Honda DW-1.
Old Jun 12, 2017
Not sure which ATF the OP is using but Valvoline Maxlife full synthetic and Castrol (MVI) Multi Vehicle Import blend synthetic are well documented as acceptable substitues.
Old Jun 13, 2017
Originally Posted by Megalodong
I think this seems to describe my issue pretty well. There doesn't seem to be a clean solution to this?
And yea I've used only OEM Honda DW-1 for my drain/fills.
Thanks for the replies.
