2001 Power Steering comes and goes?
2001 Civic EX 4DR AT
Hi all, here's my story.
For the last couple of winters, the power steering might whine on its first start of the day, but quickly be quiet and work fine. I never bothered looking under the hood.
This past fall, the power steering stopped working, and the fluid level was low and I topped it off with Prestone "Asian" (supposedly made for Honda) PS fluid.
All was fine until a week ago when the power steering stopped working again, but the fluid level wasn't low, I couldn't see any leaks, and there were no bubbles (that I could see) in the reservoir.
Taking another look at it a couple days later (the power steering still wouldn't work) but I let it warm up for a bit longer. After 10 minutes or so, the PS fluid pump started making a little noise (a "tick" sound, fast enough to sound like a fairly high-pitched buzz) for about 40 seconds (changing speed & pitch) and then stopped.
When I got in the car, the power steering started to come back. I drove around for a minute or two, parked, then turned it off. When I came back a couple hours later, it was working right on the start. I shut it down and didn't drive it any more that day.
The next morning (about 18 hours later), there was no power steering at first, but it came back after driving about 100 yards. Whined at first, but then quiet. (This was yesterday.) I drove it maybe 10 minutes all day with no more issue.
This morning (another 20 hours after last running), the power steering was working right off the bat. No noise.
What's going on? And what should I do? Replace the pump? Do I need to flush the system? I'm pretty capable with my hands (metal and wood working) but don't have experience working on cars.
Might it be okay if I do nothing?
Thanks in advance!
Thanks in advance!
The legs in the public bathroom stall
Re: 2001 Power Steering comes and goes?
Personally, I would flush the system with proper honda fluid. The way to do this is simple.
You find the PS resevoir, unhook the smaller diameter hose and plug the newly open port on the reservoir. Now take the small hose that you unhooked from the reservoir and find some way to catch the fluid that will come out of the hose. We use a section of old airhose so that it can reach a bucket on the floor, but you could use some old garden around the outside of the hose if you want.
With the small hose going to a suitable catch container fill the reservoir, and then start the engine. If the pump is working it will empty the reservoir within 10 or so seconds. Continue to fill the reservoir and pump it through, we generally use 3 bottles of honda PS fluid during the flushing, I think they are 12 fl OZ each. Reconnect the hose to the reservoir, fill reservoir, and bleed the air out of the system.
If the pump is still good you should have a working PS system again. If the pump is still flaky replace the pump and I personally would also change the reservoir. It isn't very expensive and does have a filter screen at the bottom of the reservoir which can get clogged up with gunk.
The method that I have the best luck with for bleeding PS systems is full reservoir, start car and let run for 2 seconds, turn off engine. Refill reservoir, start engine for another 2 seconds, turn off......Basically run the engine for very short periods of time until the fluid level is full with the engine on. If the pump is loud and whiny, let the engine sit for a few minutes so that the air bubbles can settle out of the fluid. The noise is caused by foamy fluid getting pumped through the system. As long as it is pumping foam it won't get quieter.
Jack the front wheels up off the ground.
While the engine is running and new fluid is being pumped through for the flush, the steering wheel needs to be cycled back and forth, lock to lock repeatedly in order to get old and contaminated fluid expelled from within the hydraulic system inside the steering gear.
I found a TSB for Odyssey that explains the flush method better than I can:
http://www.urvi.net/forumfiles/SB/A07-005.PDF
OP: why did the fluid level become low in the first place? Where did the fluid go? What else needs fixed?
Thanks for spelling out what things I should try (and what order I should try them). I think I'll go buy everything I need so I can have it all on hand when it gives me trouble again. (Or at least until a weekend when I have time.) Will be sure to get the genuine Honda fluid this time.
Need to add:
Edit: Did some searching. Do I just need a jackstand? And use the jack that came with the spare? Like I said, I work with my hands a lot, but not on cars!
I have no idea how the fluid got low in the first place, and was very surprised when it wasn't low when the steering went out again six months later. No sign of a leak then or now. Strange.
So, uh, excuse me for asking, but where should the fluid level be when the engine is running and where should it be when it's not?
Edit: Okay, I had assumed it should be checked cold, but I thought that might not be the case. I did fill it a little close to the Max level (when cold), not so much in the middle. Could that be a problem?
I suggest downloading the repair manual https://www.civicforums.com/forums/182-7th-generation-civic/235295-looking-7th-gen-manual-free-updated-13.html
The last post on this thread has a link for the EM2 manual, it comes in handy.
Heres a pic of the lifting points on the car. U can use a jack to jack the car up from the front and use two jack stands on the sides, this way you can go under the car safely. NEVER go under a car using just a hydraulic jack and no jack stands, unless you want to be a pancake
Check for leaks on the rack now that u can.
The fluid should be no more than the max, so after flushing and filing, get rid of all the air and re-check to fill it up again if needed. Just how the procedure ezone linked to says.
Save
Save
Save
Save
Save
I generally go for filling it to the max line when it is running and warm.
but how do I jack up both front wheels? Obviously, I need to buy a jack, but I don't know what
See the owners manual on how to use the jack. Support the car with safety stands after raising it.
I just assumed it wouldn't be rated for lifting the entire front end. I guess it is? If I only need to spend money on a couple of jack stands, that will be great. If you think a good mechanic is expensive, try hiring a bad one
So you already know how to use the jack? Good. Make that work for this situation unless you want to buy a floor jack..
No, it is not. It may be able to pick up the weight but may not be very safe to do it that way.
Jack up one corner of the car at a time using the correct jacking locations.
This is doable, if.
This is doable, if.
This is doable, if.
The Subframe is the large rectangular heavy steel structure that much of the drivetrain and front suspension attaches to.
Edit: Wheel blocks: Do I really need two sets, one behind and one in front of the rear tires, or just the one behind? You probably need enough blocks to prevent the car from moving forward or backward in the event a jack or jackstand slips.
We seem to have gone off on a tangent about jacking the car up.....I just mentioned that the steering needs cycled several times during the flush process to purge fluid out of the steering rack hydraulics. I mentioned raising the front wheels because it can be difficult to turn the steering wheel without full fluid flow (lack of power assist during the flush) and raising the front wheels makes it a lot easier to do this.
Ordering another set of blocks. Better safe than...dead.
Cheers.
