Aftermarket injectors any good?
Old Dec 1, 2016
longdrive352's Avatar
longdrive352 is an unknown quantity at this point
I have a 98 HX. I just hit 250k mi, and I'm now dealing with my second injector going out in about a year and a half timewise. Is that unusual, or typical? It's definitely a bad injector as it is not making any pulsing noise at all..
I'm thinking of replacing the whole set to be proactive. I've run across a set on eBay... All 4 new... Bosch four hole versions.
http://www.ebay.com/itm/New-1996-200...JYErSI&vxp=mtr
Are these a bad idea or a decent alternative? I've read about injector balancing in the past, and I've always thought the concept made a lot of sense.
Does anybody have experience with these plastic body units?
Thank you for any info,
JP
Old Dec 2, 2016
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Aftermarket injectors any good?
Assuming it is the proper flow rate and assuming it is an actual "bosch" injector and not a counterfit part they should be fine. The problem is that you only have the sellers word that they are actually a bosch built injector. There is a global problem with poor quality parts getting branded as name brand parts.
As far as plastic bodied injector are concerned. Most fuel injector on port injector engines have gone to plastic bodies. You can get them from denso, keihin, and bosch in recent years as OE on many newer models.
Old Dec 5, 2016
That makes a lot of sense. I appreciate the input. I ordered them, but I'll post if i have any issues.
