Clearing tranny codes
Hi all. I've got a 2004 civic LX that just blew a tranny, and I just dropped in a low mileage used one from the wrecker. My question is, how can I clear the transmission error codes? This thing sat without battery for two days so obviously it doesn't clear by pulling a fuse. The nearest dealer is 2.5 hours drive away and that's a long way in limp mode.
Thanks for any suggestions.
Re: Clearing tranny codes
You must have brand new codes to figure out.
Or a trans replacement didn't fix any of the codes you had?
Unplug a completely different sensor to cause a new code. TPS is a good one.
Key on until code stores. Then disconnect battery and reconnect that sensor.....and see new code is gone, leaving all current codes.
You have your own code reader, of course? What codes does it have?
