Major oil leak discovered when replacing water pump
Old Aug 21, 2016
Subftc's Avatar
Subftc is an unknown quantity at this point
ID:	89013My son bought an 01 LX and whiten two days it overheated. It had no water in it so I filled it up and when thermostat open and let water flow all the water came out around timing belt cover. I suspect a bad water pump. I had time today so I was going in to change timing belt and water pump and discovered oil all over lowers portion of timing belt area.
1. Does the water pouring from timing belt area sound like water pump.
2. I am going to replace the following items.
Timing belt
Timing belt tensinor and spring
Camshaft seal
Crankshaft seal
Oil pump o-ring
Oil pan gasket
Water pump
Valve cover gasket.
Is there anything else I should replace.
3. Someone recommended replacing oil pump. It is very expensive part that seems to work well. Seems overkill to me but am open to suggestions. I think just replacing o-ring is way to go.
Old Aug 22, 2016
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Re: Major oil leak discovered when replacing water pump
you're a good dad!
Old Aug 22, 2016
mikey1's Avatar
that is the only thing in that area i can think of that could possibly leak coolant, and going by the orange silicone, it looks like somebody has removed the oil pan in the past
PS....2000 posts, yay me
Old Aug 22, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
There's one more you can knock off while the valve cover is off and its the round plug/seal opposite the camshaft seal (where the distributor would be if it had one). This way you eliminate all possible leak areas!
Other than that sounds like you got all your bases covered
Old Aug 22, 2016
You got the timing covers off. Fill it with water and figure out exactly where it pours out of.
Overheated? Head gasket may be blown. Head could be warped.
Reseal as necessary. In 14 years fixing these cars, I've never had to replace one.
vdubbin95
Dec 2, 2015 01:52 PM
rollaguy
Suspension
Nov 11, 2015 07:48 PM
tuvok
Oct 24, 2015 02:09 PM
bambuski
Dec 16, 2001 05:57 PM
SpdRcrChk
Nov 15, 2001 11:33 AM
