Fuel pressure test fitting?
I want to perform a fuel pressure test on my 2005 Civic LX.
The prcedure says to
to connect gage at the quick disconnect fittings. what I need to know is: Where cn I get the adapter needed to connect my fuel test gage to these quick disconnect fittings. Is there some other way that I can measure fuel pressure at the rail?
thanks foe any help or suggestions
CDF
CDF
Re: Fuel pressure test fitting?
If you can not find the part at an auto shop you could pull another fuel rail from a scrap yard and cut it.
Then use a hose and hose clamps to mate it to the pressure gauge.
There are no fuel pressure test ports provided. You would have to either "T" into the system at a quick connect joint, or maybe clamp the tester hose to the steel pipe that comes up to the firewall --without the plastic tubing or fuel rail connected, or if the tester has a fitting that could slide into a quick connect and seal up that could work too.
Pump problems are extremely rare. These aren't like American cars LOL
Friends,
I'm also trying to diagnose an issue and could use a place to tee into the fuel line before the injector rail. Can someone link to a coupling or adapter that will allow me to connect to the fuel line quick disconnects to a common test kit? This is the one that can be rented from Autozone's and O'Reilly's stores:
http://mobiledistributorsupply.com/2...t-kit-oem.html
Clamping the gauge to the steel barb at the firewall won't work if you want to get readings while the engine is running. I can't imagine it's too hard to get fuel line pressure reading for our Civics, but I can't find any simple solutions. I'm consigned myself to ordering an adapter/coupling. Thanks for your time!
PS. Pump problems may be rare, but a number of different things could cause low pressure at the rail. Thanks again.
jimmyfloyd
Nov 21, 2015 11:10 AM
danfry21
Oct 31, 2015 02:26 PM
PimpBot5000
Nov 26, 2001 07:15 PM
