Front bumper "guard" fell off... do I need to replace it?
Old Nov 30, 2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
So I was driving down the freeway last week and a freaking metal "ball" rolled across the lanes and I couldn't avoid driving over it. As I went over it it definitely made contact with the under body. Later, I discovered that the rubbery plastic barrier under the front bumper almost completely fell off, so I removed it (see pic below).
Question is, do I need to worry about crap hitting the under body while driving? My car is 13 years old and so I'm not inclined to spend much money on it, and not sure how much repairing/replacing it would cost.
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/SwNyXlQUn4CxEwdkDPA85gBJyAxy1CGmH6U_nVQQjdQ?feat=e mbedwebsite"><img src="https://lh3.googleusercontent.com/-gUXUhAWMxck/Vl0MBn76UVI/AAAAAAACsUE/LDzQIUYxbQ0/s800-Ic42/IMG_2658.JPG" height="600" width="800" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/104666588397510338705/DropBox?authuser=0&feat=embedwebsite">Drop Box</a></td></tr></table>
Old Nov 30, 2015
Re: Front bumper "guard" fell off... do I need to replace it?
Of course. If you hit something big enough to damage the oil pan or transmission, you're gonna be in for some large expense.
If you meant "do I need to worry about the rubber strip?" I'd vote no. I see many of the cars missing that one, no obvious issues.
Old Dec 1, 2015
h4ldol's Avatar
Thanks! I was referring to the rubber strip, although I wonder if I should get it checked out "just in case." Nothing wrong so far, no fluids leaking or "weird" (that sounds so ignorant I know) sounds, or any issues while driving it, so not sure if I need to shell out a a couple hundred dollars just to have the dealer eyeball it.
Old Dec 1, 2015
PMI's Avatar
PMI
PMI has a spectacular aura aboutPMI has a spectacular aura about
If you want it inspected, I would take it to any tire/suspension/muffler shop. Tell them what you hit and ask for an inspection, AND to show you any damage. A dealer is often prevented from having customers in the bays by their insurance rules. A muffler shop, not so much. An inspection is often only $10~15 including rotating tires.
Old Dec 1, 2015
Lean your head under the front bumper and take a look?
Old Dec 1, 2015
h4ldol's Avatar
Thanks, I think I'll try that!
I wouldn't know what I'm looking at though. I will probably take a look though as I have a pair of sloped/raised wheel ramps and it looks like the bumper cover on one side got jarred slightly. I never reattached all the plastic clips when I last removed the bumper cover (to install headlights), only put the screws back in, so I should probably put those clips back in finally too.
