Temp Gauge Working/Not Working
Old Sep 11, 2015
srtlat's Avatar
srtlat is an unknown quantity at this point
New to this forum so please be gentle. lol
Have a 04 Civic and the temp gauge it being a little funny.
Was driving and noticed the gauge was still on cold after driving it for a while. Got to my destination and turned the car off then back on and the gauge was working perfect. Some times its working great other times it doesn't work at all?
Any ideas? Is it the temp sensor?
Thanks
Old Sep 11, 2015
Re: Temp Gauge Working/Not Working
Check engine light on?
Codes?
Old Sep 11, 2015
srtlat's Avatar
Codes?
Nope. No codes or check engine light
Old Sep 12, 2015
srtlat's Avatar
Also does the 01-05 civics have 3 coolant sensors like the prev generation did?
Old Sep 12, 2015
Ok then run the gauge sweep test (cluster self test) to see if all the gauges are capable of operating correctly.
Best to do this test WHILE it's acting up, because if you do it while everything works you most likely won't find a problem..
You could also try smacking the dash while the gauge shows low, see if that gets it working again.
7th gen uses a single coolant temp sensor for the computer and gauge.
Previous versions used two separate sensors.
All of those use a separate temp switch to run the fan(s).
7th gen:
The PCM reads the temp sensor, then sends that info to the gauge cluster through a data bus along with RPM and VSS info....
If there is a total failure (open circuit) of the temp sensor it should set a code in the PCM---- but just inaccurate might not set a code.
This system gives a person more ways to diagnose though IMO, simply get a scanner that can read the computer data (live datalist) and see what the coolant temp reads from the PCM and compare to what the gauge says. Then decide if someone is lying, and who.
Old Sep 17, 2015
srtlat's Avatar
Replace the coolant temp sensor and still getting the problem
Old Sep 17, 2015
I guess you didn't do any of the suggestions in post #5?
Xuhme
21
Aug 7, 2023 03:40 PM
werdnahall
May 17, 2015 11:37 AM
Rushfan1
May 6, 2015 01:20 PM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
