01 auto jerking at higher rpms
Old Aug 29, 2015
Galbir's Avatar
Galbir is an unknown quantity at this point
Hey guys.
I bought a civic ex 01 auto from a used dealer a few days ago and it's been running fairly normal since. Except three things.
For one when I first start it for about 10 seconds there is this high pitched sounds that getslouder when I accelerate but goes away fairly quickly. The dealer said the belts were just changed and that they just need to break in. I doubt this but i'm a simple pleb.
The second thing is that when I'm on the interstate and I try to speed up past 60 the car bucks. It is fine if I feather the gas up to 75 but if I press it too far it happens.
Lastly when I put it in lower gears like 2 D blinks but if i turn it off and back on it stops.
I took it by a part store and got a egr valve code.
Thanks for the help guys.
Old Aug 29, 2015
Galbir's Avatar
Re: 01 auto jerking at higher rpms
Someone on /o/ said it was the timing belt needing to break in and that I should floor it. This scares me.
Old Aug 29, 2015
Originally Posted by Galbir
Hey guys.
Take it back, make them fix it?
Wait, the dealer already got your money. You are history to them.
Loudass screech? Alternator belt isn't tight enough. (GUESS)
Good job. Break in already happened, belt stretched a bit and is now too loose.
Not enough description on this one.
Blinking D light means there are fault codes related to the transmission.
Probably need a better scanner than what they have to get trans codes then.
What's the EGR code? What number was the code?
You been trolled. Stick a Sharpie in your
Old Aug 31, 2015
Galbir's Avatar
Sorry about the slow response bud.
The jerking happens when I press the gas pedal too far it jumps up to 4k and then goes down to 3 then back to 4 in rhythm with the jerking. Once I pull off the gas it stops. Sorry I didn't describe it better.
Just noticed when I put it into D3 it shows as 2nd on the display.
I crossed the obd sensor and got some codes that the auto store didn't.
ABS:
13 Front Wheel Sensor
Tranny:
45 or P0780?
SRS:
51 Internal Failure Of The SRS Unit
Cel:
12 EGR Lift Sensor
22 Vtec pressure valve?
70 tranny
Can transmission codes even be read this way? The D had 4 slow blinks and then 5 fast blinks but not a long no blink and 1 fast blink for the 01 part of a 45-01 code.
Also the whining sound only happens when the A/C button is pressed ac can be on fine but not that button.
Thanks a ton for the help bud.
Old Aug 31, 2015
from here I can't tell if that would be an engine issue or a trans issue.
Ain't right, but why?
Linkage misadjusted?
Range sensor misadjusted?
Wrong trans installed (SLXA instead of BMXA)??
IDK.
ABS:
Left front open or short. If the ABS warning light wasn't staying on, this is probably an old code. Erase if possible and see if it returns later.
Tranny:
45 or P0780?
P0780 was not in the list of possible codes.
Under engine blink codes I found 45 but nothing under transmission.
SRS:
Erase it, see if it comes back. If it was set due to low battery voltage or power surge, it should stay gone after erasing. If it returns the same code, the SRS control unit is probably bad.
If you aren't positive you got SRS system codes cleared properly, set a new different code on purpose and see if you can get that to erase.
Cel:
12 EGR Lift Sensor
P1491, would need some testing. Valve may have stuck, wiring issues, etc.
P1259, first thing is make sure the engine oil is at the full mark. Low oil is the #1 cause of that code.
And if the computer goes into limp mode because of this code, that might explain your surge complaint at the top.
70 tranny
Also was not on my list, it might represent P0700 which would just be a marker to indicate the presence of other trans related codes.
Erase engine and trans codes and see which ones return?
I can't rely on blink codes at work, I use the factory scanner software. "P" code descriptions are usually more accurate than blink codes.
So it's not a loud belt screech?
AC systems do make noise.... compare to another like car?
SalPal
Jun 3, 2015 03:44 PM
Wild Cranker
May 19, 2015 06:10 PM
Ninetyatecivic
May 9, 2015 07:48 PM
McD
Apr 16, 2015 10:46 AM
Diznavis
Jan 6, 2002 09:13 PM
