Knock Sensor Replacement Help Needed
Old Feb 9, 2015
cbjfan2009's Avatar
cbjfan2009 is an unknown quantity at this point
Good morning,
I diagnosed my car as having a bad knock sensor using my OBDII code reader (as well as a free diagnostic by Meineke confirming this). The question then becomes, what is the best way to access these little pains in the @$$?
I've seen suggestions to attack it from underneath, reaching up passed the oil filter (or removing the oil filter for better access). I've also seen suggestions to attack it from the top by removing the intake manifold. The bottom seems less direct and more of a pain for maneuvering/reaching... but I'm clueless about the manifold and how to remove that. I'm still new to DIY engine repairs, so if you're going to suggest removing the manifold is easier, please link a picture of what I'd be removing. I think my engine runs on magic, after all.
If I attack the knock sensor by removing the manifold, will I be damaging any gaskets or other parts that I'd have to replace when I put the manifold back? Do I need to temporarily remove and pipes, hoses, wires, etc? If so, what risk is there that I'll damage something really important?
Any and all input is greatly appreciated!! Thanks!
Old Feb 9, 2015
mikey1's Avatar
Re: Knock Sensor Replacement Help Needed
well..........
whats easier to remove and replace?
your oil filter? or your intake manifold?
take the path of least resistance
Old Feb 9, 2015
What if it's just the wire unplugged or chewed off by a rodent?
Old Feb 9, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
I'd go underneath, the oil filter route, FWIW.
Old Feb 10, 2015
cbjfan2009's Avatar
I couldn't know this for sure, so I took it to a shop for diagnostics, as well. They measured proper 3.5v to the sensor, it just wasn't sending out a proper signal. The sensor is bad.
Thanks for the input, bsmiley and mikey1. I am going to proceed with the under-route. I might try to take pictures and post them here afterwards so it could help others.... we'll see.
CarStuff
Dec 6, 2020 12:52 PM
docmartin14
Jul 30, 2015 11:26 AM
bsmiley
Apr 27, 2015 01:27 PM
Myredjonda
Apr 14, 2015 07:00 PM
thesushiboy
Apr 12, 2015 02:54 AM
