civic oil pan question
No amateur/no professional
Does the "band" on the oil pan come off? Meaning, on the bottom of the pan there is piece that almost seems like it could come off - the screws compress it against the pan when installing? Is it a separate piece? On the ends of mine I can compress the last screw with my fingers and hear the "crunch" of grit in there.
Thanks.
Thanks.
Re: civic oil pan question
Since you are not even set up that I can tell your year or anything..maybe it's here in the fish..http://www.collegehillshondaparts.com/
The rail is part of the pan. It's used as a stiffener so the bolts are less likely to deform the stamped steel.
IIRC it's only spot welded in a few places to keep it in place. I don't think it's welded the entire length.
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
