2002 Honda Civid SI
Old Oct 27, 2014
maryanntorres70's Avatar
maryanntorres70 is an unknown quantity at this point
2002 Honda Civid SI
I am hoping to get some advice. My 2002 honda civic si vtech months back over heated due to the fans not working and I changed out the thermostat. Last week it over heated again forcing the hose to come off. I understand I may need to change out the thermostat again but here is what confuses me. I don't even have to start the car, just turn the key and the temp jumps to high and stays that way when started. Before I changed it last time the temp started out cold and slowly rose. No fans are working but the car starting out on hi is what is confusing me. Im just not sure if I should change out the thermostat again or try something else.
If anyone is willing to give me advice I would appreciate it. Thanks
MaryAnn
Old Oct 27, 2014
Re: 2002 Honda Civid SI
So it's been overheated at least twice now. Could have severe engine damage because of the overheating events.
Could have radiator damage now too.
Was the thermostat repair just a wildass guess, or was it actually diagnosed as the cause of the problem?
Did the original problem (fans not running) ever get corrected?
I'm guessing not?
I'd connect a scanner to the computer to see what it reads the temp as, see what codes are stored in it and see what the freeze frame shows (if it has a ECT related fault code in it).
Then I'd evaluate if the head gasket has been breached and attempt to evaluate the extent of the damage to the engine, see if it needs to come apart for further inspection and evaluation.
AND see why the fans don't run.
Then sit down and make an estimate for repairs.
If this is the Si with a K20 engine, this ain't gonna be easy or cheap.
Old Oct 28, 2014
I should have said that the first time it overheated was last year and after I changed the thermostat the fans came back on and no problem since so I thought the fan problem was solved. Also there was a code for the etc sensor and I also changed that. (thank god for youtube) The second time it overheated was last week. Once I put back on the hose, filled it, then let the car run the temp automat went to high. I let the car run a bit and the fans never came on.
Thank you for the advice, I will get it scanned for the codes today and go from there.
One last question please, I changed out the intake to a cold air intake and do to constant rain I changed back. I did this my self so could I have done something when disconnecting and reconnecting everything to cause this?
Nothing is easy or cheap with the car.
Old Oct 28, 2014
Need to fix the gauge problem. Without that, it's difficult to judge temps from inside the car. That's why I said to read (scanner data list) what the computer sees for coolant temperature.
If everything worked after the reinstall, I'd guess it's not related to the current problem. But then again, anything is possible. Inspect?
CarStuff
Dec 6, 2020 12:52 PM
nicholaai
Apr 27, 2015 05:54 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
vino
Nov 3, 2001 11:08 PM
