02 Civic Overheating Issues
Old Sep 12, 2014
imperialized's Avatar
imperialized is an unknown quantity at this point
Exclamation 02 Civic Overheating Issues
Vehicle is a 2002 Honda Civic EX 1.7L vTech (Running the D17A not D17A2 engine as I replaced it)
Alright I need some insight here from all my car loving friends. My 02 Civic has been having off/on overheating issues. First, I will describe what it does and then what I have done to try and fix it. Primarily when at idle, the temp needle will draw up to about 3/4 hot (from the MAX on gauge) then when I would drive it went back down. However, that is not always the case. Sometimes it will stay hot. It is very sporadic and sometimes I can drive hours without it overheating.
What have I done?
-Replaced thermostat (twice, to ensure it wasnt faulty)
- used paperclip to jump relay (fans work, indeed both do)
- ran my own fan switch the ensure that they WILL ALWAYS be on when I flick the switch
- Tested water pump by starting car cold w/out radiator cap and watched it start flowing (said pump is about 2 years old)
--The plan today is to flush the radiator and replace the radiator cap. Any other suggestions??
Help!!!
Old Sep 12, 2014
GolNat's Avatar
Prelude Owner
Re: 02 Civic Overheating Issues
Is the overflow filling up?
Old Sep 12, 2014
Welcome to the "Bad news, it's a head gasket" forum!
You never said how low the fluid in the radiator was then it got hot.
Were any of those factory parts?
Make sure this works
Old Sep 13, 2014
Ok, so I flushed the radiator (not the heater core other than letting the car run with a radiator cleaner and water).
The overflow has been full, but then it goes into the radiator.
After flushing the system and letting the car idle for ~20-30 mins, it got about half-way hot (as far as the temp gauge goes, slightly above operating temp) but after turning my fans on (with my switch) it went back down. I purchased the temperature sensor but was waiting to put it in until I knew that the flush didnt fix the problem. It seems to be running ok, considering that a slight up in temp after a prolonged idle is normal.
-- Both thermostat were aftermarket.
-- The fluid level in the overflow was to the top (never boiled over, never left any liquid on the ground) but once the it got hot it flowed directly into the radiator (I believe)
Extra notes:
- Oil change 2 days ago (not milky when drained, looked like the traditional used oil)
- Also replaced the radiator cap
Old Sep 13, 2014
KillerCam251's Avatar
KillerCam251 has a spectacular aura aboutKillerCam251 has a spectacular aura aboutKillerCam251 has a spectacular aura about
Do a block test
Old Sep 13, 2014
Originally Posted by KillerCam251
Do a block test
Half of the leaking head gaskets will PASS that test, that's why I can't use it.
Old Sep 13, 2014
Do a block test
Forgive my ignorance but I don't know what that is. Pressure testing?
Old Sep 13, 2014
Its a blue chemical in a test tube you stick in your radiator, and start your car up and idle it till operating temp. After that you suck air from the cooling system past the tube with the chemical in it and if it turns yellow that means there is hydrocarbons in the system which indicates a blown head gasket. You can also pressure test the system and set it at operating pressure and leave it for like an hour it if drops at all that can also indicate a blown hg as a cooling system is sealed. Also try a compression test the limit per cylinder is over 135 psi. Also check your plugs and see what colors they are.
Old Sep 13, 2014
bluciv's Avatar
bluciv is an unknown quantity at this point
OP I'd drive it now and watch it. Have you been experiencing any loss of coolant? Just make sure you bleed all the air out of it.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
skywalker
Nov 8, 2001 05:04 PM
