Fan/Overheating Question
Old Aug 30, 2014
Kiotzu's Avatar
Kiotzu is an unknown quantity at this point
Hi,
I have an 02' with 1.7L in it and I will occasionally overheat(not to the max just above normal) but if I drive it usually returns back down to normal operating temp. It tends to only overheat at slow speeds or when not moving. I suspect it may be my fan not kicking on, as they don't seem to turn on when I turn my a/c they do not turn on either.
Just replaced the thermostat so I eliminated that from the overheating.
Thanks
edit: got the fans to work, will test later tonight.
Old Aug 30, 2014
Re: Fan/Overheating Question
Problem!
What did you do?
Old Sep 4, 2014
Kiotzu's Avatar
I charged the A/C and then unplugged and plugged in the A/C compressor.
Still having the overheating problem, heat goes dead while idling but goes down when driving, coolant being pushed out the res, pretty sure head gasket is gone.
Old Sep 4, 2014
OneJzSupra's Avatar
OneJzSupra is an unknown quantity at this point
check your oil for radiator fluid. if it looks god flush your radiator and see if that fixes it.
Old Sep 4, 2014
Sounds like it's a blown head gasket so far.
Easy to test and prove it.
Old Sep 4, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Check your tire pressures. If they are low, fill em up to 30psi. Use nitrogen. See if that fixes it.
Old Sep 4, 2014
OneJzSupra's Avatar
lol what?
Old Sep 4, 2014
Originally Posted by OneJzSupra
lol what?
Well played, good sir.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
