2003 Honda Civic LX Blown engine
Old Jul 29, 2014
jgooch1415's Avatar
jgooch1415 is an unknown quantity at this point
Question 2003 Honda Civic LX Blown engine
My Civic overheated last week and the mechanic recommended replacing the engine due to low compression and a lot of the componits in the engine are melted. It has 190,000 miles on it. So i called the Honda dealer and they said they found an engine with 80,000 miles on it that they can put in it. It comes with a 12 month 12000 mile warranty. Parts and labor. They can do that for 2700 dollars. My only hold up is the tranny having 190000 miles on it. What is every experience with these trannys? Should i expect it to go 300000 miles plus? What should i do in this situation. I owe about 4000 dollars on the car. Thanks
Old Jul 29, 2014
Re: 2003 Honda Civic LX Blown engine
Crapshoot. Roll the dice!
Old Aug 1, 2014
jgooch1415's Avatar
yep it is! Thanks
Old Aug 6, 2014
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
In all honesty, most used engines include the tranny, look on eBay.
Old Aug 6, 2014
BlueEM2's Avatar
Whachya lookin at?
Tranny should be fine. If your overly worried about it you can probably do a full tranny rebuild for ~600 dollars. They will inspect everything and replace a bunch of bearings inside that tend to go. The problem is if they find something else wrong. I honestly thing this is a far better method than buying a used transmission and slapping it in. You will not know what your getting. Just make sure you find a really, really, really good shop to do the work, and make sure they deal only with transmissions. Also make sure they use OEM parts.
Old Aug 18, 2014
jgooch1415's Avatar
Thanks everyone for the tips! Looks like i am going to replace the engine. Now i just need to save up the money to do that.... Thanks!
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
smmahan
Apr 15, 2015 08:17 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
