Battery disconnect ?
can somebody tell me how to disconnect my battery? LOL J/K
now seriously.....im going on a two week vacation and leaving my car parked at the airport the entire time, im thinking about disconnecting the battery while its parked before i leave, good idea or no?....i would hate to come home to a dead battery
is the draw from the radio etc enough to drain my battery in this time?
Re: Battery disconnect ?
Why, certainly!
Call the Fire Department, they can disconnect the battery for you with a set of these:
*I* was serious. I thought you were too!
Have you ever seen how the Fire Department disconnects the battery in a burning car?
HINT: See above pics
Wouldn't be a half bad idea IMO.
Not normally, assuming the battery is in tip-top condition and has a full charge (measuring the specific gravity of the electrolyte).
However...... If the battery is in marginal condition or just partially charged, even though it sounds just fine when you crank it each morning, it may be enough of a drain to be a problem 2 weeks in the future.
I can hear it now....*Click* *Click* *Click* "DAMN!"
now seriously.....
*watches temp gauge like a hawkboss* :D
Sometimes filling the cells with distilled helps the problem, but not if the alt is flaking... which also points to the importance of the alt's mounting bolts.
Easiest solution is a new battery if you have the cash... but without proofing the rest of the charging system it's gonna happen again fast.
Oh -- and I just picked up one of these from WalMart: link
Pretty brainless. plug in, hook it up in your garage, choose AGM and 15A, and let it do the rest. $40 online; bought it to maintain my bike batt but it'll also charge my 7th gen batt if need be.
thanks for the info,
to be honest i dont really check my battery all that often, i never have in the 4 years until i put a voltmeter on it the other day for fun, it is actually a cheap "discount" battery, so after 4 years it doesn't owe me anything,
never needed a boost or had a problem starting one time, i guess i will just disconnect it and hope for the best......Lol
