overheating issue and tried everything
Old Jun 23, 2014
irishgirl88's Avatar
irishgirl88 is an unknown quantity at this point
My 2004 civic lx is overheating again. Last time it was the relay. This time around We replaced the relay,thermostat,coolant censor,fan censor and drained antifreeze and put new in. Also tried burping it and nothing happened. The fan doesn't want to kick on unless the a/c is on. It works when a/c is running. The car has 150k miles on it. Thanks for advice in advance.
Old Jun 23, 2014
mikey1's Avatar
Re: overheating issue and tried everything
your head gasket is probably blown,
does the coolant level in the overflow bottle rise up really high?
as in to the top, or possibly overflows?
that is a sure sign of head gasket failure
Old Jun 23, 2014
No it didn't, level stayed the same. There also is no antifreeze in the oil. Checked that. And no white smoke from exhaust.
Old Jun 23, 2014
mikey1's Avatar
my money is still on the head gasket,
what type of coolant did you use when it was replaced?
Old Jun 23, 2014
My husband informed me drained only out of radiator, not a complete flush. And he put in 50/50. We have a appointment made for it to go in on Wednesday. Just hoping not to expensive fix, but have a feeling it will be. thanks for replying also.
Old Jun 23, 2014
mikey1's Avatar
50/50 but what brand name?
these engine are very particular to coolant type, the only thing you should be using is honda OEM blue coolant, anything other than that is a big mistake,
if you have not used honda OEM blue coolant, then the first thing i would do is drain the entire system and replace it with the blue coolant
Old Jun 23, 2014
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
+1 on the head gasket
Replace your head gasket. Your overheating will stop.
FYI, oil and coolant don't mix in this engine when the head gasket is blown.
Also, see this link: https://www.civicforums.com/forums/3...reference.html
Old Jun 23, 2014
If you keep the AC on (so fans run), does it still overheat?
If you jumper the 2 wires for the coolant temp switch in the thermostat housing, do the radiator fans run?
thana
Jun 15, 2020 07:05 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
