01 Civic EX starting problems
Old May 27, 2014
KHouck316's Avatar
01 Civic EX IHE
KHouck316 is an unknown quantity at this point
So i have an 01 Civic EX with 188k miles. Has an AEM intake, megan racing headers, and megan racing full exhaust. Recently, about every 2 or 3 days, i try to leave for work in the morning, temperature outside about 60 degrees, and it wont start. I turn the key and the dash lights up but no sound from the engine. It starts right up when i jump start it and it will start up every time after that for about 2 or 3 days then it happens again.
About everyday when i first start the car and put it in first gear the engine bogs in and out. Acceleration stops for about 10 seconds, even when gas pedal is to the floor i get no acceleration, no engine sound, no rpm's. I keep pumping the gas pedal then 10 seconds later, all power restored, accelerates great.
Check engine light throws 'random multiple misfire' 'cylinder 1 misfire' and 'cylinder 4 misfire'.
I had the battery, alternator, and starter tested at local parts store, all are up to par.
Changed and gapped spark plugs a month ago, replaced all ignition coils a month ago, changed oil, brake fluid, clutch fluid and power steering fluid a week ago. 2 new o2 sensors about a month ago.
Any insight would be appreciated. Im not mechanically inclined, nor am i challenged. Teach me something and i will catch on.
Old May 27, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: 01 Civic EX starting problems
Those two are related.
What plugs did you use, and what did you gap them to?
Old May 27, 2014
KHouck316's Avatar
01 Civic EX IHE
Plugs are ngk, copper ones i believe. The gap is right between 1mm and 1.1mm
Old May 27, 2014
kinakoes2's Avatar
If it's a copper-electrode plug, then it's not the correct one. The correct NGK is PZFR6F-11, a platinum plug. These coils are pretty particular about having either the right plat Denso or NGK plugs, and *not* touching the gaps. They are gapped correctly out of the box.
If your parts droids make a habit of dropping their plugs, then check with a known good gapping tool. But make sure that gap is 1.1mm.
Old Jun 3, 2014
KHouck316's Avatar
01 Civic EX IHE
Well i put in some new OEM plugs and misfire code went away. Still bogs in and out when i first start it up. Also getting p0420-bank 1 code. Let that fun begin.
Old Jun 3, 2014
kinakoes2's Avatar
Yeah 0420 is a cat code, and a clogged one is the most likely cause. New cat, or j/y cat from a newer EX...
BTW, it's not lost on me that '420' here, means the engine can't breathe.
Old Jun 3, 2014
KHouck316's Avatar
01 Civic EX IHE
Where would the cat be? Right after the headers? I have this exhaust on:
http://www.meganracing.com/product_d...d=154&catid=13
Theres no cat anywhere along the exhaust so would it be after the headers? Please enlighten me.
Old Jun 3, 2014
kinakoes2's Avatar
On a cat-back system, the Megan part starts after the cat. The stock system has a downpipe with a cat at the back of it. The upstream sensor hooks up at the front of #4, the downstream obviously at the rear. <<Link
So really, the system only reduces backpressure AFTER the cat, which is how they're legal (noise aside). The stock system has a shorty 4-1 that bolts to a downpipe that has the cat integral to it, so it's not the easiest exhaust to get power from, without custom-fabbing your 4-2-1's long-pipe headers (my preference for street system) to the cat.
TL;DR -- your cat is still probably clogged. Need to see if you can find either a relatively clear j/y downpipe/cat, or a new one, or weld in another cat possibly? I'm not the expert on that last part; the mods in the Mods forum would be the ones to ask.
Old Jun 3, 2014
KHouck316's Avatar
01 Civic EX IHE
Thanks for that link. Helps to have a visual. I think tomorrow im going to take the cat off and take a look inside. That means ill have to take off the whole downpipe right? Yay labor.. I wonder if theres any way to unclog it if its not in really bad shape.
Old Jun 3, 2014
KHouck316's Avatar
01 Civic EX IHE
I just got a brain blast! I think i know how it got clogged!
When i first posted i wrote how the engine bogs in and out when i first start the car sometimes. When that happens, i pump the gas pedal until the engine fires up again. When i pump the gas, theres probably no spark, so the raw gasoline flows down the exhaust clogging the cat!
Yay or nay?
Old Jun 3, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Nay.
Old Jun 3, 2014
KHouck316's Avatar
01 Civic EX IHE
Well then! Still dont know why it bogs. Did it today. Im gonna check the spark plug wires. Faulty connection maybe?
Old Jun 3, 2014
kinakoes2's Avatar
Well if you ran it for a while with an intermittent spark problem, that richness is what will kill the cat. You get soot from a lot of heat, which can cover the cat's inside surfaces eventually.
Any multi-point FI system will have no need for an accelerator pump (or anything other than sensors to determine fuel injected), so that can't be it.
Plugs/ignition: did you replace with the proper Densos (PKJ20CR-M11) or NGKs (PZFR6F11)? Do the connectors for the coils have proper contact (has been the problem with other 7th-gens before)?
CarStuff
Dec 6, 2020 12:52 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Braun
Apr 23, 2015 09:03 PM
McD
Apr 16, 2015 10:46 AM
SSMatey
Apr 13, 2015 06:09 PM
