civic bogs down then dies
Old Aug 10, 2013
matbarnes18's Avatar
matbarnes18 is an unknown quantity at this point
Had my 02 civic in shop yest, for a Lower Ball Joint replacement and also had a new cat and 2 o2 sensors put in. Last night, it randomly bogged down and lost all power while I was driving. It cut off, and when I went to start it, it would only bog down and die. If I hit the accelerator it will make a deep noise, almost like a totally built engine would (which is NOT the case for my car.) Then it would also misfire. Had it towed, and looked at it today. All sensors are fine, didn't throw any codes. Fuel pump is fine, it primes, but it doesn't get any fuel to the fuel line under the hood. No stream of gas came out when checked the gas valve. Motor shakes terribly when it starts. Any ideas of what this could be?
Old Aug 10, 2013
Re: civic bogs down then dies
it will backfire* when I press gas. Not misfire..
Old Aug 10, 2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Just because the pump runs doesn't mean its pumping. If you aren't getting any fuel to the engine your pump is suspect.
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
WeRkX
Nov 1, 2001 10:33 PM
