Radiator reserve empty?
Old Aug 8, 2013
M00n3at3r's Avatar
M00n3at3r is an unknown quantity at this point
Hey everyone, this is a simple question. I was under my car tonight replacing an engine mount, and noticed that my radiator reserve is empty, is that something I need to worry about?
Old Aug 8, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Radiator reserve empty?
Yes.. definitely. When the car is cold pop the rad cap and check to see if there is any coolant in there. You need to fill the reservoir to the minimum line and properly bleed the coolant system... after a really good bleed fill it up between the min and max lines. If it happens again you have a more serious problem that needs to be taken care of. Use only OEM honda coolant.
Old Aug 8, 2013
M00n3at3r's Avatar
...how do I bleed it? I'm assuming you don't mean like a flush? I checked a little while later and it is almost to the top of that area...you know with the cap...what if I don't use oem? I have a brand new, well 3 years+ bottle in my shed that has never been opened. It says I can add it to any coolest any color, why couldn't I use that? This is the next new thing I'm learning so I am asking as much as I can to gain any possible knowledge. Would this maybe effect my A/C? Ie when I turn the ac on the power drops, and I rarely get actually cold air? If you have a diagnosis for that problem and don't mind tossing in an opinion I would appreciate it.
* just watched a video on bleeding the radiator, do you just mean open the cap, poor it in the reserve, cap it run the car, let it cool then check my level again?
Old Aug 8, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
It's smelling like an HG job to me.
Old Aug 9, 2013
BlueEM2's Avatar
Whachya lookin at?
This is how you properly bleed the coolant system:
1. Make sure car is cold
2. Open the hood
3. Remove the radiator cap
4. Jack up the front of the car (optional but recommended)
5. Start the car
6. Make sure your heat and fan are off.
7. Watch the level in the radiator, as it goes down, add Honda OEM coolant.
8. Once the car reaches normal operating temperature (halfway on the gauge), turn the fan to the highest setting.
9. Turn the temperature dial to full hot.
10. Continue filling the radiator full of coolant as the level drops down.
11. When the coolant no longer goes down your done.
12. Make sure the reservoir is somewhere between min, and max.
13. Replace the cap on the radiator.
14. Put the car back on the ground.
15. Put the cap back on the overflow tank.
16. Close the hood.
17. Shut the car off.
18. Close the door.
19. Lock your doors so nobody steals your swag.
LoL that's pretty much it. It's very very easy but it's time consuming especially in the winter.
Old Aug 9, 2013
How about a simple leak....or neglect? Either would let the thing go empty.
FTI I see plenty of cars (not just Hondas) that need the reservoirs topped off at every oil change. Skip this step a few times (Walmart, JizzyLube, et al,) and the reservoir goes completely empty.
OP: When was the last time it was properly filled? Establish the rate of consumption and look for obvious leak evidence before getting panicky.
Old Aug 9, 2013
Matt_75's Avatar
I assumed the OP means the reserve is filled to the top along with the A/C won't cool issues. Not sure.
Old Aug 9, 2013
BlueEM2's Avatar
Whachya lookin at?
Yeeea an empty reservoir is not a definite indicator of a major problem. But, it is an indicator to bleed and fill the system properly. If it does it again relatively fast you could have something more serious on your hands
Old Aug 9, 2013
Matt_75's Avatar
I guess you missed my reply.
Old Aug 9, 2013
BlueEM2's Avatar
Whachya lookin at?
Yea I did .. stupid firefox .. < gotta blame it on something haha. The only way the AC kicks off is if the car starts to overheat to protect the engine. Is your reservoir full or empty?
Old Aug 9, 2013
M00n3at3r's Avatar
Sorry for the confusion, the reserve is like bone dry, the radiator it self is filled up to the cap on the top. And the ac is like I'm driving I turn it on and the engine has like this noticeable power drain and I have to work the pedal harder to get up to speed. I know my battery needs changing, but isn't the compressor run from a belt?
Old Aug 9, 2013
Then simply refill the coolant reservoir to the proper level. Keep an eye on it, see what happens.
Any automotive AC system requires several horsepower from the engine to operate the compressor. Easily felt when you have a puny engine, not so noticeable when you have a powerful engine.
BUT you sound like you have a problem with the AC, and as long as the engine is not overheating, that's a completely separate issue and should be addressed as such.
Old Aug 9, 2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Ya, smells like a leak to me too. Look under the car for a trail from a leak, hose junctions, water pump area, etc. Not completely ruling it out, but headgaskets usually puke out the overflow rather then empty it. Like was said fill it and make sure the air is out then go from there.
Old Aug 9, 2013
M00n3at3r's Avatar
Alrighty, thanks everyone for your help. It just got me worried that something may be wrong. One of this you fix one thing only to find another.
tooly145
Sep 5, 2015 01:05 AM
bdrickybd
Jul 25, 2015 04:35 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
