Lower Control Arm Bushings
Old Jul 8, 2013
joe_cool97's Avatar
joe_cool97 is an unknown quantity at this point
Hi. I have a 2002 civic Si with 185 000KM.
The LCA bushings are pretty worn in the front, and are starting to make some noise going over bumps.
I acquired brand new LCAs with bushings already pressed into them.
My question is, while I am installing these new control arms, should I be replacing anything else while I am in there? (ball joints, tie-rod ends, stabilizer links, etc)?
Any help would be greatly appreciated. I want the front end of my car to be solid, and if the parts are relatively cheap enough, I'd like to do a little bit of maintenance down there.
Thanks
Old Jul 8, 2013
GolNat's Avatar
Prelude Owner
Re: Lower Control Arm Bushings
Well the front sway bar end links are connected to the LCA and you have to remove half of it so you might want to do them. I replaced mine and the sterring felt tighter.
Not easy unless you have a press but the ball joint could probably be done. Check to see if its leaking and/or loose.
Tie rods are easy but don't need to be removed to do the LCA. Might as well check them along with the ball joints.
fordover
Jul 11, 2015 09:10 PM
ballmich
Jul 9, 2015 11:59 AM
CivicsClass101
Jul 9, 2015 11:14 AM
