02 Civic Coupe NO Clutch Pressure
Old May 9, 2013
briantal's Avatar
briantal is an unknown quantity at this point
I installed and bleed both the New Generic master and clutch cylinder i have ran fluid through all tree lines and still and it flows through properly .. But when mounted no pressure and no fluid running to the slave from the master cylinder
this is a em2 02 coupe
Old May 11, 2013
04 Honda Civic's Avatar
Re: 02 Civic Coupe NO Clutch Pressure
When you bled it did you have air bubbles coming out?
Mount the slave, and the master completely.
Fill the master and bleed it.
Bleed it in a container with brake fluid already in it, and make sure the end stays submerged in the fluid during the whole process.
Get a buddy to pump/lift/pump/lift the clutch a few times.
Close the valve on the slave, and you should get SOME pressure at that point.
Make sure you dont run the master dry or else you need to start over again.
It takes ALOT of pumping if you didnt bench bleed the master. Ask me how I know..
Old May 12, 2013
Pushrod on the pedal may need adjusted.
Poopies
Apr 20, 2017 11:36 PM
miatabro
Jul 17, 2015 12:12 PM
shaejb15
Apr 26, 2015 07:44 PM
15EXCoupe
Apr 19, 2015 09:26 PM
CapYoda
Nov 11, 2001 05:17 PM
