new engine put in, overheating issues
Old May 1, 2013
2oo3EX's Avatar
2oo3EX is an unknown quantity at this point
I blew the engine in my 2003 honda civic so i replaced the block. Everything is now put together and the car runs fine. But when i took it for a test drive the temp gauge shot right up to high in less then a minute. I was wondering what you guys think could cause this, im fairly sure i didnt miss any plugs except for one coming off the a/c pump which i cant find where it goes.im fairly sure it isnt the head gasket i cant find coolant in the oil its blowing hot air And its a new gasket . Im thinking it could be a bad water pump or something else idk any help would be great
Old May 1, 2013
mikey1's Avatar
Re: new engine put in, overheating issues
sounds like the system may just need to be bled or "burped"
however, do not let it overheat during the process
Old May 1, 2013
ONLY one minute?
First thought: Something electrical is lying, or the water pump has no impeller (or it is slipping on the shaft).
A good wire diagram can be your best friend. So can a scanner.
It's attached to the fan shroud.
Meaningless. That's only one of about 15 different ways a head gasket can fail.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
tylerginevan
Apr 27, 2015 12:29 PM
civic_gt
Apr 19, 2015 08:15 AM
deus-ex
Apr 13, 2015 12:29 PM
