Engine noise
Alright, I hate posting car problems on the forum, so this goes to show how frustrated I am. I decided to try and investigate this intermittent sound I've noticed, did so after an oil change.
Got this nasty sound coming from my engine. Really only shows up at <10% throttle between 2000-3000rpm, and at 15-25% throttle from 3000-4000rpm
Tried to pinpoint the sound, and it seems like its coming from the bottom end, either cylinder 2 or 3.
Idle is smooth as its been as long as I can remember, no loss of power that I've noticed, no metal in the oil (unless I pull the oil pan and it proves me wrong), still burns a bit of oil, same as she has been for a while now.
Here's a (sideways) video for your listening pleasure
Re: Engine noise
I'd say that it sounds like a loose (worn) rod bearing from here.
(With the disclaimer about this being a laptop, sounds consistent with lower end bearing noises, etc.)
Not real loud when the oil is cold, but gets much more noticeable as the oil gets hot?
Cancel each cylinder and repeat the revving to isolate and identify any that make significant differences, then pull the pan and rod cap(s) to confirm.
7th Gen Civic DIY Enthusiast!
Re: Engine noise
Kind of sounds like a thread that was started last year. See link below.
https://www.civicforums.com/forums/3...ml#post4621959
Re: Engine noise
Re: Engine noise
I was thinking it was the same, really just posting to try and disprove my thoughts. Wishful thinking, is more like it
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
