Misfire
Old Jan 29, 2013
0civic4's Avatar
0civic4 is an unknown quantity at this point
Misfire
Good Day
I have an 04 civic SI with 200 000Kms,
The past little while I have been receiving a misfire in cylinders 1 and 2.
Spark plugs were changed, compression test done and coils checked by swapping to other cylinders.
CEL still comes on for 1 and 2.
Shop is talking about going wire hunting,
I don't really feel any symptoms of a misfire except perhaps for noticeable shaking at very low rpms, especially while creeping forward at an idle
Any advice is much appreciated!
Adam,
Old Jan 29, 2013
mikey1's Avatar
Re: Misfire
the next thing i would test is for fuel/fuel injector....
Old Jan 29, 2013
Re: Misfire
Canadian SI with 1.7 engine? US SI with 2.0?
Post the freeze frame data.
I bet the EGR distribution plate/chamber needs cleaned.
Old Jan 29, 2013
04 Honda Civic's Avatar
Re: Misfire
SI in canada is the same as EX in USA.
Old Jan 29, 2013
SlammedciVic66's Avatar
SlammedciVic66 is an unknown quantity at this point
Re: Misfire
You can check it out on ur spark plugs wires aswell man. My gf had a 98 ford explorer n it had misfire from the spark plug wires. I changed them n it went away. Easy way to check that is at nite time. Wait till dark. Start up ur car n open up the hood n take a carefull look at ur plug wires n if u see sparks from ur wires then u should change them. Hope that will help u out buddy. From stephen
Old Jan 29, 2013
Re: Misfire
Duh, shoulda noticed the KM.
If the freeze frame says it set the code while driving, not stopped and idling, then I bet the EGR plate needs cleaned out.
Old Jan 30, 2013
mikey1's Avatar
Re: Misfire
these cars do not have spark plug wires
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
