Noise coming from left shock
Old Dec 26, 2012
SSMCivicCoupe's Avatar
SSMCivicCoupe will become famous soon enough
I have this squeaking noise coming from my driver side coilover. I replaced the top hat a couple of days ago because it was making noises everytime i would turn. I checked axles, lower control arm bushing, wheel bearing, sway bar end links and everything looks good. My tie rod ends need to be replaced because I sort of damaged them while putting my coilovers on. But all in all everything looks fine to me.
Heres a video.
http://s1120.beta.photobucket.com/us...7cf6e.mp4.html
Old Dec 26, 2012
lazlong's Avatar
Re: Noise coming from left shock
Definitely sounds like rubber... if that helps any.
Old Dec 27, 2012
mikey1's Avatar
i believe there is a bearing at the top there, did you replace it? is it installed correctly?
Old Dec 27, 2012
04 Honda Civic's Avatar
Spray the top of your strut with a penetrating oil the noise will go away, your bushings are worn a bit.
I did this and the noise stopped for now.
Old Dec 27, 2012
Yeah its installed correctly.
This might just work, I will give it try and see how it goes.
Old Dec 28, 2012
Doenst really mean the bushings are good, but it will buy you more time.
I did it a year ago and its still quiet. I know they need replacing soon though ride just isnt as nice as when I first got the car..
Poopies
Apr 20, 2017 11:36 PM
civicns
May 8, 2015 09:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Sparty
Nov 15, 2001 04:55 PM
eX2ooo
Oct 5, 2001 12:19 AM
