Engine Noise -- Safe to drive?
Old Dec 8, 2012
gixxer600's Avatar
gixxer600 is an unknown quantity at this point
Hi,
I have a 02 Civic which has approx 150k miles and has been meticulously cared for. During my last drive, I noticed a new noise coming from under the hood and, as a precaution, have not driven the car since. The noise is best described as a ticking/flapping albeit not very loud but noticeable and appears to lessen once the engine has warmed up.
The car is a bit overdue for an oil change and does have a consistent leak due to an oil pan that is somewhat due to be replaced. A friend mentioned that the noise may be due to a low oil level.
In any event, I plan to take the car into the local service shop middle of this week. Unfortunately, I need to do a bit of driving before I can take it in.
Would appreciate any input/suggestions with regard to fixing the issue and/or determining whether the vehicle is safe to drive for a few more days.
Thanks in advance,
gixxer
Old Dec 8, 2012
Re: Engine Noise -- Safe to drive?
Check the oil level first, make sure it isn't empty.
Hopefully you can do this in a garage, not out in the wind:
Fire it up with the hood open, then run out and sniff the engine compartment----if you can smell raw exhaust (like a lawnmower), the manifold cracked. Shut the hood and drive it.
Xuhme
21
Aug 7, 2023 03:40 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
smmahan
Apr 15, 2015 08:17 PM
Unstoppable
Nov 7, 2001 11:50 PM
