Air/Oil Separator?
Old Nov 20, 2012
cb450sc's Avatar
cb450sc is an unknown quantity at this point
Air/Oil Separator?
I have a 2005 Civic SE (Canadian) . I have been on a hunt for the location of the PCV and with the help of this forum I was able to find it. The PCV is located next to the oil filter. It screws into something called the air/oil separator. I just purchased a Haynes manuel and it confirms this. The manual also states that this air/oil separator is supposed to be removed. It does not say that to clean it but rather to "use a solvent and gasket scraper to remove residual gasket material. Is this supposed to act like a catch can for excess bypass junk? Has anyone ever serviced this?
Old Nov 20, 2012
mikey1's Avatar
Re: Air/Oil Separator?
i have never removed mine,
if all you need to do is replace the PCV just unscrew it, i did mine from the top, it was a little tight and tricky, if i remember correctly i used a 17mm deep socket and a swivel extension with ratchet
Old Nov 20, 2012
cb450sc's Avatar
When you changed your PCV, did you find any oil gunk in this air/oil separator?
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
mistahlorax13
21
Nov 18, 2015 12:47 PM
wingsfan19
15
Sep 2, 2015 02:15 AM
