em2 drivers side front wheel bearing
Old Nov 12, 2012
colbyem2's Avatar
colbyem2 is an unknown quantity at this point
i just replace it 2 weeks ago and its bad again, athough i know my aligment and tires are bad what could be the cause of this possibly aligment?
any input helps thanks
Old Nov 12, 2012
mikey1's Avatar
Re: em2 drivers side front wheel bearing
most likely an installation error or non-oem part, or both
Old Nov 12, 2012
or something else.
what makes you think they are bad?
Old Nov 14, 2012
colbyem2's Avatar
i havent had time to obsvre it yet altho i jacked it up, wheel didnt move at all, so thats most likely not it, but just repaced axle and ball joint to and i think the azle is hitting the ball joint grease fitting on sharper turns sounds dumb but it was really close when installed
Old Nov 14, 2012
04 Honda Civic's Avatar
Axle nut needs to be tightened to spec.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
ej8
Apr 13, 2015 06:36 PM
tattedlariat
Apr 12, 2015 07:55 PM
