Possible to pull check engine light codes with no scanner?
Old Nov 7, 2012
kevin2001's Avatar
kevin2001 is an unknown quantity at this point
Question Possible to pull check engine light codes with no scanner?
Is there a method to pull Check engine light codes on a 2001 Honda Civic LX Coupe?
Old Nov 7, 2012
GolNat's Avatar
Prelude Owner
Re: Possible to pull check engine light codes with no scanner?
I think there are 2 pins you can jump together on the obd2 plug but I'm not sure. Autozone does free scanning!
Old Nov 7, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Go to YouTube and search for EricTheCarGuy and he has a whole video he did recently that explains how to read Honda codes without a scanner. Awesome stuff.
Old Jan 7, 2015
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
You can try bridging pin 9 and 4 on the obd2 connector. When you look at the connector it will be pin 1 (top right) and pin 4 (bottom).
https://sites.google.com/site/hondalioness/srs
Old Jan 8, 2015
That's to see what's causing an SRS light to come on. Not check engine light.
Unless I'm sadly mistaken, then kudos to you.
Old Jan 8, 2015
It should work...DLC pin 1 is the old SCS circuit, pin 4 and 5 are grounds.
An OBD2 reader is much quicker.
Why did we drag this thread back from the dead?
Old Jan 8, 2015
nsrhonda89's Avatar
I have a SRS light on my car and was looking to pull the code. My cheap scanner can't pull SRS code. I was goggling and this thread came up, so I just updated it. Now I have to go fix SRS code 4-1.
Old Jan 8, 2015
4-1 Open in front passengers seat belt tensioner
First erase code and see if it returns immediately
If it does
Unplug and reconnect the connector, see if the code goes away.
If it does
Search for "terminal fretting", and "Stabilant 22A"
Old Jan 9, 2015
mikey1's Avatar
back in the day i had a 5.0 93 mustang, i remember i could check codes using a continuity tester by hooking it up somewhere under the hood and counting the flashes of the light, cant remember the exact process but it did work,
have not seen anything like that on a car recently, or ever with honda,
Old Jan 9, 2015
mikey1's Avatar
Old Jan 9, 2015
Originally Posted by mikey1
or ever with honda,
Jumper the SCS connector to set base ignition timing (distributor) AND to get flash codes from many control units.
Newer cars have the SCS line pinned in the OBD2 data link connector instead of a separate 2 pin connector. Stull has similar abilities, but with flash codes you're kinda limited as far as actual usefulness when comparing to real OBD2 fault codes..
Old Jan 11, 2015
nsrhonda89's Avatar
Thanks ezone. I'm getting 2-1 and 9-3 code now. I used a friend Snap-On scanner to cleared the code and 2-1 came back.
2-1 Open circuited In Passenger Air Bag Module
9-3 Faulty Driver Seat Belt Buckle Switch
Old Jan 11, 2015
So there wasn't a 4-1 code?
9-3 needs a drivers buckle (they all do, common failure)
Got any handy info about your car? Year, trim, # of doors, etc?
2-1....Open in passengers front airbag inflator...and it's a dual stage inflator.
Is your car included in the Takata airbag recalls? Has it been done already?
Old Jan 11, 2015
Open glovebox all the way.
Connector is next to glovebox opening, this pic is pretty close.
Unplug and reconnect pass airbag connector, then erase and recheck for current codes.
Old Jan 11, 2015
nsrhonda89's Avatar
I have a 2001 Acura EL 4 door similar as the Honda civic ex with SRS. I removed the negative cable and cleared the SRS code twice, but the SRS stayed on. I got it scanned yesterday and those code was in the history and I cleared it. 2-1 code came back after driving the car twice.
It has the Takata airbag both was replaced 1.5 years ago at the dealer. Oh I forgot to mention that I reseat and clean the connector in step 11 already.
Do I need to bridge a 2 ohms resistor like the manual says? I will try to unplug and reconnect the connector. Thanks
Old Jan 11, 2015
2 ohms resistor
2 ohm is used to simulate the resistance of a good airbag inflator.
IF inserting a resistor in place of each of the two firing circuits simultaneously makes that code go away, it would prove your wiring and control unit are good up to that test connection point in that circuit....leaving the other half of that connector all the way to the airbag itself as the source of the problem.
Was the warning light already on when you took it in for the recalls?
Old Jan 11, 2015
nsrhonda89's Avatar
I think I found the problem. This round connector on the second image came loose, but I can't reconnect it. I can feel a hole on the side of the airbag where it suppose to go. No, I wasn't getting any light before the recall work was done.
Old Jan 11, 2015
2nd image, yep that looks like the culprit. My guess is shoddy work done by the person doing the recall, the connector didn't get LOCKED into place..
I'd say take it back if it were recently completed, but I doubt you would get anywhere because it's been a long time now.
You probably need remove the complete unit to reconnect the part.
Remove the 3 nuts in the first pic, then I stick a pry tool thru that gap area between the 2 nuts, thru dash frame and the round thing and gently pry the unit upward until an edge pops loose up out of the top of the dash. Then you can work the edge up until the unit is loose and remove from the dash. The dash-colored cover is quite flexible.
The connector that came loose must be oriented a certain direction (it may fit 2 ways when the pins are aligned, 180* apart), and if that one came loose there's nothing to say that the other one was correctly installed either. If you look into the end of the inflator where that connector came out, there are little dark gaps that kinda form a "T", the connector needs to be oriented likewise.
I can't get pics for a while.
Old Jan 11, 2015
nsrhonda89's Avatar
Ok, Thanks. I will try to remove it next week.
Old Jan 11, 2015
I can probably get pics later in the week if you want some.
Old Jan 11, 2015
nsrhonda89's Avatar
Sure, that will be nice.
Old Jan 18, 2015
nsrhonda89's Avatar
I removed the airbag, fixed the bend pins and connect it back. I find the connector was a little loose, so I used electrical tape to band both connectors to the airbag body.
Old Jan 18, 2015
Sorry I didn't get any pics, I was only at work 2 days last week and I haven't had a passengers inflator to replace since my previous reply.
The connector that you found out of place was never correctly installed during the recall, apparently. Those little round connectors have a death grip once they are correctly installed.
Old Jan 18, 2015
nsrhonda89's Avatar
Yes, that is what it looks like. The other round connector was tight. The light hasn't come back.
thana
Jun 15, 2020 07:05 PM
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
