d17a2 transmission problem
Old Oct 30, 2012
05_HondaCivic's Avatar
05_HondaCivic is an unknown quantity at this point
so when i replaced the input shaft bearing on my 05 civic i forgot to put those two little washers back on the bottom of the shaft. Now when i drive its hard to put into gear sometimes. Also it will pop out of gear and feel like its not even all the way in. Would not putting those little washers back in cause this..or did i mess up somewhere else down the line???
Old Oct 31, 2012
mikey1's Avatar
Re: d17a2 transmission problem
well your going to have to tear it apart again to put them in, so just double check everything as you go
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
jmdcivic
May 20, 2015 09:52 PM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
Myredjonda
Apr 14, 2015 07:00 PM
