P0235 BUT with 44mph on 2002 Civic
Old Sep 2, 2012
vtcycle's Avatar
vtcycle is an unknown quantity at this point
Hi All,
I have read many posts on this engine code P0235, but my milage has gone up to 40-44mpg, because I drive mostly downhill
Anyways, the code has been reset a few times, and I am not experiencing accelleration lag, or bogging. The only thing amiss is once in a while the temp gauage goes up to H once ever 50 - 90 miles for 30 seconds or so.
From all the posts I have seen, none actually have a good picture of the Knock Sensor location on my 2002 Honda Civic EX, VTEC engine.
Here is a picture of the firewall side engine with the oil filter removed.
Any ideas?
thanks in advance.
michel
Old Sep 2, 2012
Re: P0235 BUT with 44mph on 2002 Civic
You mean P0325, right?
Apparently it is slightly above that large coolant pipe, above the oil pressure switch. The service manual says to remove the intake manifold to change it.
This is pretty similar locationwise, see the green arrow:
HTH
Old Sep 3, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Originally Posted by vtcycle
Hi All,
Any ideas?
thanks in advance.
michel
That top rusted bolt above the coolant pipe is the knock sensor bolt. You can barely see the black cable sticking out to the left of it with the green dot on it. The cable's only about 5 or 6 inches long and is going to a connector bracket.
It looks like you could get to it with out taking the intake manifold off. It's up to you. The knock sensor should be torqued to 192 in/lbs or 16 ft/lbs.
It's piece 10 on the drawing below.
http://www.hondaautomotiveparts.com/...LOCK+-+OIL+PAN
Old Sep 24, 2012
vtcycle's Avatar
Well, the engine light went off and stayed off long enough for vehicle inspection. I figure it is not the knock sensor but a loose wire or connection somewhere.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
15
Nov 8, 2001 05:06 PM
