Temp gauge
Old Jul 26, 2012
civic nighthawk's Avatar
civic nighthawk is an unknown quantity at this point
Temp gauge
If anyone can help I have 04 coupe manual trans, temp gauge doesnt work if anyone knows how to fix prob much appreciated
Old Jul 27, 2012
Re: Temp gauge
is engine light on? could be a bad ECT sensor or a bad gauge cluster.
Old Jul 27, 2012
Re: Temp gauge
No engine light fan blade came off replaced motor on that & temp sensor I was gonna try the ect sensor but I read. It was sending unit I called dealer they didn't knw if my yr had one I found diagram but only for 6th gen but I did find single grn/yellow stipe wire but not shore if its it ill try the ect first thanx
Old Jul 27, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Re: Temp gauge
1. Push and hold the trip/reset button
2. Turn the lighting switch on
3. Turn the ignition to ON(II)
4. Within 5 seconds, turn the lighting switch OFF, then ON and OFF again
5. Within 5 seconds, release the trip/reset button, then push and release the button 4 times
The beeper sounds 5 times. Then all the indicators blink. Then the odo/trip segment blinks 5 times. Then all the needles sweep from min to max back to min. Then it will run a communications check and display either all 8's or the word error. 8's are good, error means the connection between the cluster and ECM/PCM is bad. If anything doesn't work properly in test mode replace the cluster.
Old Jul 27, 2012
Re: Temp gauge
Thanx for info so I tried it all needles sweep and have all 8s temp gauge stops at almost half way then to h but way dwn was sticking I did it multiple times now gauge sweeps proper so if there's no error do u knw what could be thanx again
Old Jul 27, 2012
Re: Temp gauge
I want to say thanx for the help the communication sweep fixed my temp gauge bin driving me crazy forf a month now gd looking out
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
cferry7
Oct 3, 2015 04:33 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
