CV Axle, Pass Side.
Old Jul 24, 2012
v2famous's Avatar
v2famous is an unknown quantity at this point
CV Axle, Pass Side.
So recently I seen my CV joint was screwed up
Has anyone replaced the cv axle (half shaft)
Would it be easy for 2 people to do or does anyone recommend just going to a shop.
01 Civic EX M/T
Old Jul 24, 2012
scooty's Avatar
scooty is on a distinguished road
Re: CV Axle, Pass Side.
It's pretty easy, don't need 2 people. You need to undo the axle nut in the center of the wheel and disconnect the lower ball joint. There is a trick way to do this, search for ball joint removal trick on YT. CV axle should then pry out from the transmission.
bashea
Sep 15, 2015 04:59 AM
