P0128
Old Jul 18, 2012
nathan36's Avatar
nathan36 is an unknown quantity at this point
P0128
Have a 2002 civic 1.8L that is setting a p0128 code. The analog temp gauge takes about 25 min of highway driving to finally come up abit. Replaced thermostat and the check engine light came back on, and the gauge was very slow to move off cold. Any ideas? I was thinking it was a bad CHT sensor but that doesnt explain why the ECT sensor was reading cold too.
Old Jul 18, 2012
Re: P0128
Searched for "P0128", came back with this thread: https://www.civicforums.com/forums/182-7th-gen/349498-code-p0128.html
I'd revisit your thermostat. Use factory parts, install correctly.
Old Jul 18, 2012
04 Honda Civic's Avatar
Re: P0128
1.8 l?
Old Jul 18, 2012
Re: P0128
Originally Posted by 04 Honda Civic
1.8 l?
Good catch.
Not a N.A. market car?
Old Jul 18, 2012
Re: P0128
i dont think engine light will come on due to thermostat being bad. it will either take forever to warm up or overheat quickly. seems like a sensor issue. make sure you use honda oem thermostat and ECT sensor. not sure what else can trigger that code other than the coolant temp sensor (which also controls the gauge reading as well as vital engine performance).
Old Jul 19, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: P0128
I'm pretty sure it will if the temperature doesn't come up in a specified time. I've seen myself on other vehicles. It just says basically low coolant temperature, which would lead me to believe it could possibly be a stuck open thermostat. And the thermostat I saw was indeed stuck open.
HCivic2006
Jul 29, 2017 06:06 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
bo_red
May 4, 2015 01:47 PM
pantdino
Nov 22, 2014 03:21 PM
TheHondaNewb
Jul 20, 2014 03:01 PM
