Honda Civic 2001 won't accelerate after 20 mpg
Hey guys,
I just recently bought a Honda Civic Coupe 2001. It's a 4 cylinder: automatic.
I changed the spark plugs and did a tune up and now the car vibrates a lot, it feels/sounds like it will stall soon, and no matter how much I accelerate.. it will not go over 20 mpgs. I installed a new idle control valve but the problem persists.
It would be great to have some feedback of what I can do!
Thanks!
Thanks!
Re: Honda Civic 2001 won't accelerate after 20 mpg
Did it start happening right after you did this
What all parts did you touch?
I put in new spark plugs, did a oil and transmission changed, added new spark plug seals, and that was about it. I made sure to label all the ignition coil just in case I stuck it in the wrong place so that shouldn't be the problem. Thanks for you reply!
Is there any chance that your car overheats? have you had a full fledge drain/fill with ATF. when was the last fuel filter change? it comes with a strainer that also needs replacement. Also, Fuel Pressure Regulator needs a very thorough cleaning. I hve a 03 civic ex and its got exactly the same problem. (the car vibrates a lot, it feels/sounds like it will stall soon, and no matter how much I accelerate.. it will not go over 20 mpgs. Mine on freeways does not exceeed 40mph). I push down the pedal and pull back and push back again the pedal and it does go beyond 40mph sometimes. It depends if i have driven over 50+ mi on a very hot afternoon.
I had IAC valve cleaned but not replaced, spark plugs changed map sensor cleaned & replaced needs a thorough throttle body cleanup with EGR valve as well.
If all this doesn't change anything i then move to change both upstream & downstream Oxygen sensors.
My car 03 civic ex does not accelerate anymore even after all the work on fuel filter, o2 sensors and cleaning on IAC valve/throttlebody/egr valve/map sensors is done.
What would stop acceleration?? spark plugs, head gasket transmission issues???? overheating.
7th Gen Civic DIY Enthusiast!
Do you have a CEL?
If your car is an EX, as you mentioned, VTEC not working properly will put the car in a governing mode to prevent damage to the engine. This means only allowing the car to accelerate up to 3,000 RPM I believe. I'm not a 100% on that.
Have you done proper oil changes on the car over the years?
Passages in the VTEC solenoid could be restricted or blocked all together. VTEC also has it's own oil pressure switch as well. It also has a small screen filter assembly as well.
Below is a drawing of the VTEC cylinder head. Piece 9 is the VTEC assembly and 10 and 12 are the filter and pressure switch.
http://www.hondaautomotiveparts.com/...EAD+%28VTEC%29
I am getting the following CEL Codes on my 2003 Honda Civic EX Sedan
P1129 (Map Higher than Expected)
P0730 (Faulty Shift Control Problem)
P0505 (IAC circuit condition higher/lower than expected)
(Vaccum Leak On Engine, Dirtry Throttle Body, IAC motor defective, Poor Electrical connection to the IAC valve)
P0141 (HO2S12 heater condition Bank1 Sensor 2).
Very regular & particular about getting oil changes every 2500 mi. Never to exceed 3000mi.
Hey guys!
Thanks for responding. I couldn't figure out the issue so I had a mechanic come over and look at it. It turns out that the "Top Dead Center" aka camshaft position sensor was the problem. The car doesn't vibrate anymore and it drives like normal again.
We had the timing belt (+water pump + tensioner + blah) replaced, and that obviously didn't fix anything...
I saw the OP replaced the camshaft position sensor -- is that the same resolution for the above poster?
Balut Eating Champ
How did the routine tune up messed with the TDC sensor? Did the OP had the car running while the sensor was out? Replaced it after the ECU was on the limp mode?
My car 03 civic ex does not accelerate anymore. WIRING TO MAP SENSOR, VALVE COVER GASKET & BROKEN MOTOR-MOUNT REPLACED.
Hey guys,
Thanks!
Thanks!
or bad gap
LionSpratt
Jan 29, 2017 11:07 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
